New Holland 3415
   / New Holland 3415 #1
centell
Bronze Member
Washington, La.
3010 Kubota with 482 frt loader
I need information for a friend who has a NH 3415 who wants to know if he can install a power beyond hook up on his tractor so he could run a log splitter and other hydraulics on it.
Is this possible on this tractor and can you buy a kit and do it yourself and about what would be the cost. Just trying to help my friend.
   / New Holland 3415 #2
I believe a 3415 has the same basic hydraulic layout as all other Ford/NH compacts. You should find an hyd distribution block below the brake pedals. Connect hoses there for Pressure, Power beyond (to the 3PH) and return; and turn the selector valve. The log splitter or whatever would require its own control valve which should be power beyond capable. The flow pattern would be pump/relief valve/ log splitter valve/ 3 point hitch. Another option would be to install one or two regular remote valves. They stack onto the hitch valve below and to the right of the seat.
   / New Holland 3415 #3
you can use the same ports as the backhoe would use.
   / New Holland 3415 #4
Plumbing the logsplitter as if it were a backhoe is OK if disabling the 3PH is acceptable. I look for ways to power hydraulic equipment without disabling the hitch. This requires a power beyond installation, or the use of an OEM remote valve(s).
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
New 20' Run In Shed (A50774)
New 20' Run In...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
