I have a friend who has a New Holland 3010 tractor. It only has 200 hours on it but is about 8 years old. It has developed a “miss/cutting out” when running full rpms. He has changed the fuel filter, added sea foam (at advice of dealer), changed air filter. He is gets his diesel out of my tank (farm fuel) and my tractor (International 1066) is running fine, and I treat my diesel with Power Service octane boost. This miss is not constant either, it seems to be not getting fuel sometimes We have also taken the fuel cap off in case there was a clogged fuel cap, no change.
When you first start the tractor up it will run ok, but after you run full rpm for a minute it will miss, sometime so bad that if you roading the tractor and have to pull over and stop to let traffic by that it will die. It always starts back up ok. It also seems to run ok if you let it idle a few minutes then run full rpms.
It also seem to run ok in the mid rpm range, but since he uses pto on it usually runs it at full rpm
We felt it is not getting fuel, but you also get a smell ever once in while of what I call a “rich diesel smell” from it This problem has been going off and on for several months but as you can tell by total hours, tractor does not get used that much. We checked the lines and diesel seems to be flowing ok out of the lines. Tractor is never really stressed, it is used for shredding and I use it to rake hay with and sling fertilizer
Any ideas or suggestions
