New Holland 2120 no forward or reverse
   / New Holland 2120 no forward or reverse #1
MrTea
New Holland 2120, John Deere 990
Hello,
I just purchased a 1999 New Holland 2120 that will not operate in forward or reverse. The loader works and has plenty of power. The power steering does not work. I did some research and read where a couple people had a diode go out in their control module. I checked this and that particular diode was fine. It was clear someone had removed the module before me(mounting bolts loose,pried on box)
I do have the flow chart for the HSS but the first step is to test the hydraulic relief valve pressure. Is there a test port? TSC for a gauge? Any other suggestions where to start?
   / New Holland 2120 no forward or reverse #2
Check to see if the PTO works when you try to move the tractor. If not the main clutch is out. Power steering is a dedicated system and a separate problem.
With the tractor in gear and moving the shuttle shift forward and reverse the pto appears to operate as it should. I don't have an attachment available to put it under load if that matters? The PTO shifts in and out solidly, the shaft coast to a stop when disengaged and you cannot slow it down by hand(not a lot of load I know)
Scott
   / New Holland 2120 no forward or reverse #4
If the main clutch were the culprit the PTO shaft would not turn at all when the tractor was refusing to move. Sadly your problem lies within the EHSS system.
I appreciate the help. Each part I can eliminate gets me one step closer to finding the culprit.
Today I found a wire off the switch connected to the HSS lever, no help. I found a ground wire off by the solenoids, no help except I did start seeing a signal to the solenoids when the lever is moved. When the lever is moved the test light is bright then dims a little. This seams like the control module is working. If I pull a solenoid could I see it operate?
I just checked the solenoids and they seam fine. I read the the voltage is suppose to drop to 5v so that would explain the dimming of the light. There is a cable that ges from the clutch to just in front of one of the solenoids. Mine pulls out when the clutch is depressed but doesn't go back in unless you push it. Does anyone know what this is for?
At this point I would say my control module is good unless I am missing something? What could be next?
Except... My clutch does work. Also I think it has separate forward and reverse hydraulic clutches so I wonder the likelihood of them both being out.
   / New Holland 2120 no forward or reverse #10
Or no regulated circuit pressure or flow to and through the valve to lock up the F and R clutch packs. Time for a service manual. If you get an OEM repair manual be sure to get the supplement that covers the EHSS variation you have. It is separate from the 1920/2120 manual which predates your tractor.
CountyLine 5ft Rear Grader Blade Attachment (A46683)
CountyLine 5ft...
2016 Ford Explorer AWD SUV (A46684)
2016 Ford Explorer...
(2) New/Unused Welding Helmets (A48837)
(2) New/Unused...
24ft Corral Panels (A49251)
24ft Corral Panels...
2016 Ford Escape AWD SUV (A46684)
2016 Ford Escape...
