New Holland 2012 workmaster 55 hydraulic pressure
   / New Holland 2012 workmaster 55 hydraulic pressure #1
Mallard1
Arkansas
John Deere 4320
I have a 2012 new Holland workmaster 55 and if i pull into a pile of dirt and get a full bucket it doesn't want to curl until i back up. I'm looking to see if the bucket is slightly too big or if the pressure relief valve many have been set a little low from the factory. I cobbled enough stuff together today to make a test hose and all i lack is a gauge and i can pick one up tomorrow. it looks like the pressure relief valve is on the side of the joystick block and should be easy to adjust.
I just wondering what pressure should i see when i hook up my gauge to one of the hoses on the front end loader. thanks for the help.
I found in the manual the the pump is supposed to put up 2535 psi . I checked the pressure using the quick fitting for the loader lift line and the pressure release was set at 2100psi. I bumped it up to 2400 psi now but don稚 have any piles of rock left to test. I should have some delivered soon .
Anyone see any issues with what I did?
   / New Holland 2012 workmaster 55 hydraulic pressure #3
You should be okay. Just be careful, the higher you take pressure the easier to overload the tractor. :thumbsup:
2018 Bobcat T590 (A50123)
2018 Bobcat T590...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
43029 (A51691)
43029 (A51691)
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
2000 International Log Truck, Triaxle, Log Bunks (A52384)
2000 International...
2004 Ditch Witch RT70M Ride On Trencher (A53117)
2004 Ditch Witch...
