davidkanoy
I have a Ford/New Holland 1920 manufactured in 1992 that has developed a strange hydraulic issue. The tractor has a NH 7108 Loader with a WR Long model HJ2 4-1 bucket. I currently have a bush hog brand bush hog on the 3 point hitch. So here's the issue: Unless I have the 3 point hitch in the full up position I have extremely slow loader operation. With the tractor at normal idle and I raise the 3 point hitch the engine slows down 100-150 RPM and the hyd pump arrears to be in a strain. With the 3 point hitch full up, the loader is very fast up and down and curl. With the 3 point hitch in any position other than full up the loader is very slow. The 4-1 bucket in almost non functional in either position of the 3 point hitch.
Here's what I've done so far:
1)Changed the hyd fluid & filter and found brown flakes of a material that appeared to be paint chips or maybe brake shoe material in the top of the filter.
2) Installed a Harbor Freight 5000 PSI gauge in series with the input of the loader spool control and another 5000 PSI gauge in the "A" (open) port of the WR Long 2 position 4-1 bucket Energy valve.
With the 3 point hitch in any position other than full up, I have almost no pressure on the loader control gauge and as stated above the loader is very slow. With the 3 point hitch in the full up, the loader gauge reads 2550 PSI and the loader operates very fast & curls fast. With the 3 point hitch in the full up position the 4-1 bucket port "A" gauge reads 2550 PSI in open, close or center and will not open or close the bucket at all. With the 3 point hitch in the down (or anything but full up) the 4-1 bucket will open & close very slow and has no power.
The on-line New Holland parts breakdown of the hydraulic piping shows a Manifold Diverter, Control Valve Assembly with an adjusting screw. I tried moving the adjusting screw to the other (counterclockwise) position but I did not see any change. This Diverter is making a high pressure fluid rushing sound (when I operate the loader with the 3 point hitch in the full up position)
that I don't remember before this problem started.
I also tried changing the 3 point hitch speed adjusting knob (Turtle/Rabbit), but that had no effect.
I think the hyd pump is OK because I can develop 2600 PSI.
As I stated above, I found those flakes of material in the filter, might a relief valve be stuck open?
ANY thoughts, opinions, suggestions or prayers would be greatly appreciated.
Thanks in advance,
David
Thanks in advance,
David
