New Holland 1720 Alternator wiring problem
   / New Holland 1720 Alternator wiring problem #1
jnhelton
new-holland 1720
Anyone have a color-coded wiring diagram for the alternator on a 1720? I discovered I don't have a warning light for the alternator. In my investigation it turns out that 2 wires in the wire bundle within inches of the alternator aren't terminated. A white red striped with brown spots wire that goes back to the light. A white with brown spots (no stripe) that goes to the "L" terminal on the Alternator.
If I connect these, the light works perfect but the tractor won't stop running with the ignition switch. The reason is that the "L" wire carries a constant 2 volt current when the alternator is spinning. This voltage bleeds back to the fuel stop solenoid and is just enough to keep it from shutting off.
HELP! Thanks
   / New Holland 1720 Alternator wiring problem #2
Hi -
I bet if you put a diode in the line that feeds the idiot light, that will stop the run on. A radio shack 276-1661 (6A @ 50v) is what I have used in the past. The stripe (cathode) end of the diode faces the alternator in the circuit.
Tom
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
JOHN DEERE 4100 TRACTOR (A51243)
JOHN DEERE 4100...
1982 LeeBoy Motor Grader (A52128)
1982 LeeBoy Motor...
2015 KOMATSU PC170LC-10 EXCAVATOR (A50458)
2015 KOMATSU...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
