New Holland 1215 No Brakes
   / New Holland 1215 No Brakes #1
garybryan
Marinez, Ca
New Holland 1215
I have a New Holland 1215 HST that has no functional brakes. I know it has a wet type disc brake set up. The pedal adjustment seems to be in order, no free play and full travel. By free play I mean,
the play between pressing the pedal and the lever at the brake housing moving.
I see that both housings have a 1/2" square drive plug on the top. I assume these are fill holes, what type fluid and how much of it is needed?
Is there another adjustment other than the pedal rod to housing lever?
Thanks in advance for all your help.
   / New Holland 1215 No Brakes #2
Gary, welcome. Not so sure your brakes are wet. They may be dry disc in which case you don't want to put oil through the plugs. Besides, wet disc brakes have a long life unless severely abused. If linkage is working and adjusted correctly, you will have to pull the covers and investigate.
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
(5) CANDY JARS (A58374)
(5) CANDY JARS...
Hydraulic Hose and Fitting Replacement Pack (New/Unused) Est Retail Value $2,650 (A59225)
Hydraulic Hose and...
2017 VOLVO VNL TANDEM AXLE DAY CAB (A58018)
2017 VOLVO VNL...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
2022 Ram 2500 (A55973)
