New guy timberdave
   / New guy timberdave #1
timberdave
Alberta
Cub Cadet Ex3200
Hi I'm Timberdave. New to any and all online communities. I have an Ex3200 that I just love. I've had this tractor - my first - for three years now. Unfortunately I may have overestimated its capabilities. Yes it will pull a 9 foot haybine and a square baler. Question is Should I have. It worked fine untill this year when I made too sharp a turn putting most of the tension on the lower left drag bar mounting pin. That mounting pin cracked and I lost all my hydraulic transmission fluid. I did notice it right away and made it back to the shop where all the fluid leaked out.
That mounting pin is part of the transaxle housing -YIKES.
Now I have to split the tractor and replace the housing. A chore I,m not looking forward to but - it is what it is.
Any suggestions
   / New guy timberdave #2
No suggestions, but welcome :)
   / New guy timberdave #3
On TBN there are forums about most makes and models of tractors. Go to the MAIN INDEX at the top of the page and scroll down until you find the model and make you desire info on. Hope this helps. :welcome::tractor:
(2) Anchor Hedge Posts (A50515)
(2) Anchor Hedge...
New Idea Pull Type Hay Rake (A50515)
New Idea Pull Type...
EPS NL45FCH45 (A47384)
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
2014 Ram 1500 Crew Cab Pickup Truck (A50323)
2014 Ram 1500 Crew...
1999 Case 90XT Skidloader (RUNS) (A50774)
1999 Case 90XT...
