goatman860
Hello, I have drug home a poor 860 that was lets say "serviced" very poorly. I have had a month crash course in the ford service manual, and lots of hands on learning. The tractor is running, and there is light at the end of the tunnel. Hopefully I will have a useful tractor soon, instead of something that is solely for busting knuckles on and cursing human beings that shouldn't be playing with tools.
Down to business
Ive set the initial timing at 4 degrees btdc at 500rpm. When run up to 1200rpm the timing has not advanced properly to 13 degrees(mabey like 9), and at 2200 the hash mark is not even close to visible for 24 degrees advance timing on the flywheel.
I had already cleaned out the chunks of grime in the distributor, degreased, and reinstalled the weights(which now move seemingly freely compared to before where they wouldn't hardly move).
How do I, or can I adjust the centrifugal advance to open up properly, to give me the proper advance curve, and total timing.
The tractor runs "OK" at any rpm when sitting, but when I drive it, it has no power, and starts to overheat which I believe is due to the retarded timing.
Thank you, and I hope some of you can impart some wisdom on a GM guy that's kind of fallen for this old ford.
Down to business
