New GT3100 owner & new to group
   / New GT3100 owner & new to group #1
nielsenphoto
Minnesota
Cub Cadet GT 3100
Hello everyone. I just purchased a new 2005 GT3100 and wanted to see what kind of suggestions, things to know, and possible aftermarket implements to look at. I will be mowing about 3 acres and using the tractor to pull a cart to clean my goatbarn. Thank you in advance and I will look forward to seeing the posts shawn@nielsen-photography.com
   / New GT3100 owner & new to group #2
Welcome to the forums, and Congrats on your new 3100 /forums/images/graemlins/wink.gif
   / New GT3100 owner & new to group #3
Congrats on the new 3100...my wife and I also just purchased a new 05 3100. It has one hour of time on it, so I really am curious how it will hold up. There is still snow on the ground here so it hasn't been outside. We will be mowing about 3 acres. We will also be pulling a 17 cu ft dump trailer with it, but have no plans of putting any other attachments on it at this time.
I have browsed the maintenance requirements in the owners manual and have also reviewed the Kohler maintenance requirements on the Kohler website. I have decided one thing already...I will not be running the oil to 100 hours. I will be changing oil at 50 hours, but will only change oil filters every other oil change. If you don't have one, buy a good quality grease gun and keep the bearings greased up. You paid good money to get features like grease zerks, so you might as well use them to extend the life of those bearing surfaces. I haven't found all the grease zerks on this tractor yet. Manufacturers like to hide them it seems. My JD has zerks you can only reach with the mower deck removed and you have to stand on your head to see them. It is worth the extra effort to look it over closely and keep it greased up. My old JD is over 30 years old and my hope is that the 3100 will be around that long.
What other types of attachments are you looking at getting? Good luck on your new tractor! /forums/images/graemlins/smile.gif
It is cold in Minnesota as well. I am thinking about getting a 3 point hitch for this and possibly a snowblower. I have also thought about the Johnny bucket as my wife and I have a small dairy goat farm and need to clean the barn. I want to utilize this tarctor as much as possible. I am trying to keep my eyes open for a small tractor with a loader to be able to clean pens, and remove snow as well. It just seems like this tractor can do a lot with it's size and attachment possibilities.
LET ME KNOW YOUR THOUGHTS.
   / New GT3100 owner & new to group #5
Well, I know these little garden tractors can be used for variety of chores. I have seen an ad for the Johnny Bucket, but that is about it. I don't know anyone who has one or have any knowledge of how convenient they are to use. I have, however, spoken with a company who builds a custom front end loader for the 3000 Series Cubs. I didn't plan on buying one, he just mentioned to me that they build them. With the hydraulics available, I suppose there are many possibilities. I would caution against overloading the tractor. Yes, it does have a cast iron front axle etc, but even at 800+ pounds (minus the deck) it is still fairly lightweight for some chores. After I get mine out in the grass and run it for several hundred hours, I will have a better idea of what it is capable of doing. It is still winter here yet in North Dakota so for the time being it just sits in the garage.
As far as the loader work is concerned, I have a Ford utility gas tractor that I use. It is large (about 48 HP) and probably too awkward to use inside a barn, but outdoors loading dirt it is hard to beat. It is old and doesn't have FWD, but it doesn't seem to need it. The new compact tractors are no doubt much more handy to use, but then, they cost over $10k and I paid less than $3K for my tractor with the loader. It has a 3 point and PTO which is somewhat unusual for a utility/industrial tractor. It has fluid in the tires, but I don't have any chains for it, so moving snow is impossible. It just sits and spins.
If your goat barn is somewhat cramped...pens etc...you might consider a skid steer type loader. I have used them before and when it comes to loader work, they beat about everything. There are alot of good used ones around also at similiar prices to a loader tractor. I would recommend one with liquid cooling rather than air cooled (the older ones). My uncle works for Melro, so the Bobcat type skid steers are my preference.
Do you rember who the loader company was? The Johnny bucket is talked about more on the mytractorforum.com site.
Do you have the normal turf tires on your machine or did you have ag-tires or a little more grippy tires put on it. I am always trying to get different ideas from other people.
Thank you for your input.
Shawn
   / New GT3100 owner & new to group #7
Shawn,....I checked back in my notes. The company I was speaking with was Concord Equipment in Hawley, MN. Their phone number is 218-483-3307...the sales reps name is Steve. I called them back and he said they are adapting a loader which they originally designed for ATVs..to fit a Cub 3000 Series garden tractor. From the sound of it, they had not put them into production yet. The loader they build has three hydraulic rams, two on the lift and one on the bucket and is controlled by the 3000 Series hydraulic system. My 3100 only has one hydraulic control so if I were to install their loader on mine, I would have to add an additional control lever.
On the tires...I have the turf tires which are standard equipment. I am using it for mowing, so that works for me. If you had a loader, better traction would be helpful I am sure. Additional weight would no doubt be a must.
I usually don't look forward to mowing season, but after getting some new equipment, I am becoming impatient with this cold weather that seems to just drag on and on. /forums/images/graemlins/mad.gif
   / New GT3100 owner & new to group #8
Welcome to the group. We also got a 3235 witha 54" mid mount morer in late 2004 we live on a farm but we put a grass catcher on it to make extra compost. Everything works good just do all the proper manitance. I really like the power lift & steering. the morer does a great job. If you get to change the morer blades I would recomend the high lift as I think they do a little better. Sorry don't know any thing about the front end loaders. Enjoy your new tractors. Good Luck Mick in South Dakota
2015 Mitsubishi Mirage Sedan (A50324)
2015 Mitsubishi...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2019 RBR Venturi 380 (A52128)
2019 RBR Venturi...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A48082)
2018 Toro...
TEST YOUR BID BUTTON! (A51242)
TEST YOUR BID...
CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A50458)
CATERPILLAR D8T...
