New GC1735MB- Leaky BH
   / New GC1735MB- Leaky BH #1
1971Gray
GC1725MB
Just bought a new GC1735MB for light work, very happy with it. But after using the backhoe for just a bit, it started leaking. The dealer said that it was a known issue and is covered under warranty with an updated part. Just posting for anyone that buys a new GC with BH to work it early, verify that it doesn't leak. I'll post part numbers of the control valve body if I get them after the repair. It is a little annoying that a new tractor can have a known issue, but nobody checks it before sell off to the customer. And the local dealer honors warranty work, but charges for hauling it to/from owners location.
Also, it runs fine, but when I switch the key on, the fuel pump whine is more of a rattle-y whine, not the smooth whine of every other fuel pump I've heard. I'll get the dealer to check it when it's in for the BH repair. Anyone else have a little rattle to their fuel pump on their GC? Is this normal?
thanks!
   / New GC1735MB- Leaky BH #2
Most likely, it uses a pulse type lift pump, also referred to as a clickity-clack pump because they have a clicking sound when running. I. Guessing you only hear it with key on engine off?
   / New GC1735MB- Leaky BH #3
lift pump makes that noise, its normal.
Thanks guys! Yes, only hear it when key is on, engine off. Can't hear it over the engine noise once the engine is running. Clickety-Clack is a good description of the sound.
TAKEUCHI TB2150 EXCAVATOR (A51242)
TAKEUCHI TB2150...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A51039)
John Deere 5090E...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2002 PETERBILT 330 CARGO TRUCK (A50854)
2002 PETERBILT 330...
Caterpillar D5K2 LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K2...
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
