new gas tank for oliver 1650
   / new gas tank for oliver 1650 #1
wango tango
Peoria IL
hey all, i'm getting my ma in laws oliver 1650 going again. its been sitting in a shed for 10+ years. we drained the tank (of course, there was close to a full tank in it :) ) and i've rebuilt the carb.
we'd love to replace the tank. do they make plastic ones? where can i find a new tank?
hoping its easy to take out. the top cover has to come off, and the muffler is tack welded to the manifold and will make it impossible to lift the cover very high. it wont fit over the diameter of the muffler.
cant wait to see this baby run. its a big tractor compared to what i'm used to. the end loader on it is huge!!!
also, i planned on changing out the guts of the distributor with one of these new electronic trigger jobbies....i forget who makes it. but the base plate is too big for the distributor housing. has anyone done this?
   / new gas tank for oliver 1650 #2
That tractor hasn't been built since 1968 or 1969, but folks do collect and restore them.
You'll probably have better luck asking this question in the Vintage Tractor forum...
   / new gas tank for oliver 1650 #3
wt, go to ytmag.com. There is a forum for Olivers as well as other brands. Tons of help there. You can probably do a search once you get there and find your answers. They talk about the distributor updates now and then. Tank shouldn't be a problem either.
   / new gas tank for oliver 1650 #4
Where are you located? Tons of used parts for these. As mentioned, you will have better luck on YTmag.com
   / new gas tank for oliver 1650 #6
Try Korves Oliver. VERY nice to deal with.
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
2021 Case Trident 5550 Spreader (A52128)
2021 Case Trident...
2021 New Holland C327 Compact Track Loader (A52128)
2021 New Holland...
2019 ALLMAND 45KW MAXI POWER GENERATOR (A50854)
2019 ALLMAND 45KW...
1995 KOMATSU WA320-1 WHEEL LOADER (A51242)
1995 KOMATSU...
2009 International Frazer Bilt X-514 Ambulance (A49461)
2009 International...
