New Forks
   / New Forks #1
ernemats
Veteran Member
Bolivar, pa.
power trac 422, and agco-allis 5660, ,1845 power trac Greenworks CRT 426
Last week I decided to try a set of clamp on pallet forks, I ordered them from Titan and they were here in a few days. I have only tried them briefly on my pt 422 and they worked ok. I used them to lift and move several ash logs about 8' long and 10" in diameter. I got them so I could use them on any of my tractors. They are easy to install and remove and they only weigh about 30 pounds eachI will try them on the other tractors sometime in the future but I see no problem with the forks working on all 3 tractors. Has anyone else tried the clamp on pallet forks?
   / New Forks #2
I have those as well. I got them on ebay. I'm a rookie but for you I'm sure it goes without saying that they are for light work regardless what they are rated at. I have a few indention's on my FEL by getting overly excited and perhaps little careless. Hand tight isn't tight enough to do much of anything. They definitely serve their purpose moving reasonable sized brush piles when you have the forks nice and tight.
   / New Forks #3
I have the longer ones and they are rated for 4000lbs. I have only used them a few times but now the Toolcat has the SSQA plate so I will be looking for a set of SSQA forks. Once I do, these will be put on CL.
8065 (A51572)
8065 (A51572)
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2003 Polaris Sportsman 700 Twin (A51573)
2003 Polaris...
