New equipment woes
   / New equipment woes #1
HRS
Georgia
So, I now have seven skinned knuckles from working on new equipment! Boy, my dealer is going to hear from me tomorrow.
I picked up three implements this weekend to go with the TC30. After backing the rotary cutter into the garage, I sat it down and walked around it to clear something out of the way. On doing so, I noticed a grease fitting on the floor. Picking it up, I saw that it went to the rear tire assemble. Great! I thought. It hasn't even been used once and things are already falling off of it. So, I sat it aside and went after the tiller.
At first, I attached the lift arms with intentions of moving it inside also. But when I went to connect the top link, I couldn't. There, with the linch pins bolt running through it, was a spacer. I pulled the pin and bolt, but the spacer would not budge. After examining the problem for a moment, I saw a bolt about five inches back, behind the top link. The left and right sides of this top hitch assemply were divided, so it would require a spacer near the top to maintain a rigid spacing. Obviously, the spacer was ment to be positioned around that top bolt, which held the two side secure. However, someone had decided to put the spacer on the hitch holes and tighten heck out of all the bolts. This wedged it in place. So I had to loosen all bolts on the top assembly and relocate the spacer to get it the heck out of the way so that the hitch could be used.
All of that went on yesterday. Today I revisited the grease nipple. Apparently, some musclehead had cranked down on it when installing and damaged the threads. It was screwed in too far and when it contacted the shaft, it lost. So for this I wrapped the threads with a good portion of thread tape and reinserted. Then I removed and applied a couple of drops of lock tight to the cut thread and reinserted. This went in nice and snug. Tomorrow, I will see if it can handle a grease gun. If not, I'll take off the rear tire assemble and return to the dealer for a replacement. He will hear about this anyway.
Finally, I decided to grease up the Covington planter, the third and final implement I purchased. If you have never seen one of these, you will have a hard time understanding what I'm talking about, but there are two disc in the front of the planter that are toed in towards each other. Their purpose is to open the soil so that seed may fall in the opening before the rear wheel closes the soil back up. Now these discs are supposed to turn. Well, I started at the back of the machine greasing and oiling it. When I got to the discs, I discovered that they would not budge. They were totally locked down. After two hours, I THINK that I might have this one figured out. A few nuts needed to be backed off a few rounds and a particular spacer needs to be extended with the use of washers by about 2 or 3.
SOoooo..... I will certainly be going over everything else on these machines with a fine tooth comb this week, checking all nuts and bolts, grease and oil traps, etc. etc.
Whatever happened to quality control. I wouldn't exactly say that I got this equipment at a bargain. Someone made some good money for throwing this stuff together. Or maybe a "Some Assembly Required" notice should be added to the paper work and owners manuals. /forums/images/graemlins/mad.gif
Fortunately, I do enjoy tinkering with stuff like this. However, I just had it built up in my mind that everything would be perfect seeing as how it is new. Having to work on all three pieces was a little surprising. These were not major problems, but still.
   / New equipment woes #2
If I bought one implement and it had a small problem that wouldn't be to bad. I am usually pretty easy to get a long with, but if I bought three and they all had problems, I would be really up set.
   / New equipment woes #3
You did not mention the brands of the attachments but an email to them explaining might help and the dealer should know; he can not fix what he does not know. I also know he can not oversee every assembly job that is done by employees but he will want to find out WHO assembled yours.
   / New equipment woes #4
"Whatever happened to quality control"
Well, in modern day "Quality", it's supposed to be engineered in.
I've been in the Quality field since I got out of the Navy in 1977. It was a good field and made some sense until ISO 9000 reared it's ughly head. Now the "systems" ensure good quality.
Also, when it comes to cutting costs...guess where the axe falls first?
   / New equipment woes #5
I understand the problems with your tailwheel zerk and your planter, but I'm not sure I understand the tiller toplink hitch spacer. From your description, it sounds like something not needed at all, but some kind of temporary piece that got installed improperly and wedged in. Can you take a picture?
I bought a new 6' KK tiller this weekend from TSC and it was a pleasure to set up and use. Everything went together perfectly and my 1/2 acre garden is very pretty. /forums/images/graemlins/grin.gif I first broke the ground with a two-bottom plow and then came back with the tiller. I made three passes over everything and now I'm ready to plant. I suspect the tilling and prep are the easy part. Now the real work is about to begin. /forums/images/graemlins/smirk.gif
   / New equipment woes #6
<font color="blue">Whatever happened to quality control. I wouldn't exactly say that I got this equipment at a bargain. Someone made some good money for throwing this stuff together. Or maybe a "Some Assembly Required" notice should be added to the paper work and owners manuals.
</font>
If it says made in the USA on it check it for lose or overly tightened nuts and bolts. Seems here in the USA we like to out-do the competition at times.
It never hurts to throughly check over any tractor or implement before using it in the field.
   / New equipment woes #7
Lesson learned the hard way:
Front wheels fell off my TC55 3rd day after delivery at the far end of a very muddy field. The bolts were not tightened down, and they heared right off. My dealer replaced the wheel and bolts in the field.
We're all human, mistakes happen...
   / New equipment woes #8
In the last two years I have purchased quite a few new implements, a lot of them were specialty implements that were shipped in, some I picked up on the way home. The biggest complaint that I have is when putting together this equipment, there is a lack of good instructions. There are instructions, but a lot of time they are quite worthless.
   / New equipment woes #9
If you have the right equipment planting is not to bad either. It is all of the weeding that gets to be a killer. You must plan on feeding a lot people or the wildlife with a garden that large.
Plastic mulch is very worthwhile on a garden that large, it cuts down the weeding quite a bit. I will be picking up about eight three by four thousand foot rolls of it next week.
   / New equipment woes #10
</font><font color="blue" class="small">( If you have the right equipment planting is not to bad either. It is all of the weeding that gets to be a killer. You must plan on feeding a lot people or the wildlife with a garden that large.
Plastic mulch is very worthwhile on a garden that large, it cuts down the weeding quite a bit. I will be picking up about eight three by four thousand foot rolls of it next week. )</font>
Actually, I plan to do initial cultivating/row plowing with an old Dearborn cultivator. It has been in our family since before I was ever born. I've used it extensively to plant and plow peas, okra, corn, and even melons. I like to start with lots of wide rows with plenty of space between them, and you need at least four rows of corn and peas to pollenate well.
I hope to use a lot of chips from my chipper shredder to cut down on the weeds and just till it into the soil at the end of the season. I've even heard of using newspaper to block weeds and till it in at the end of the season. I don't plan on that because I have this picture in my mind of newsprint gone wild and looking like litter from Heck. /forums/images/graemlins/tongue.gif I'm just wondering if you plan on leaving your fabric or do you take it up and reuse it at the end of the year?
I've done my share of hoeing and weeding in my life and one of the reasons I chose this spot for a garden was it has very few weeds. My wife's little garden near this spot had very few weeds. We'll see if I'm that lucky. /forums/images/graemlins/smirk.gif
2021 ALLIANCE NORTH AMERICA, INC AIRMAN SDG45 GENERATOR (A52472)
2021 ALLIANCE...
FRONTIER AV50H LOT NUMBER 114 (A53084)
FRONTIER AV50H LOT...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
48 PIECE HEAVYEQUIPMENT KEY SETS (A52472)
48 PIECE...
2006 CHEVROLET SILVERADO 1500HD (A52472)
2006 CHEVROLET...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
