New DK40 - Mechanical 4WD doesn't work
   / New DK40 - Mechanical 4WD doesn't work #1
bullebak
Bronze Member
Daylesford, Victoria, Australia
Daedong DK40
I have a new DK40 which has a mechanical 4WD lever switch. How hard should it be to operate? I just cannot get it in or out. Should it be soooooooo difficult?
   / New DK40 - Mechanical 4WD doesn't work #2
I have the same problem with my DK 35. The best way is just lifting the front end with the loader-then trying to move the 4 wheel drive lever.
   / New DK40 - Mechanical 4WD doesn't work #3
The 4 WD on my DK 35 always goes in and out of gear very easy.
I seldon even stop or slow down to engage or disengage. I just give a blip on the throttle peddle while pushing/pulling on the 4 WD lever and it goes right in/out..
   / New DK40 - Mechanical 4WD doesn't work #4
Just turn your steering wheel to the left while you pull the lever, it should pop right in... ;)
   / New DK40 - Mechanical 4WD doesn't work #5
I had the same problem on my CK25, I lubed the linkage and it worked better but is still a little stiff.
   / New DK40 - Mechanical 4WD doesn't work #6
Depending on the tractor all of the things above can work. Another thing to do would be to move the lever as you backup a couple of feet. It relieves the wind up of the drive train to let it come out of gear. Also, Check your tire pressure. If it is off, it can effect the windup.
   / New DK40 - Mechanical 4WD doesn't work #7
I bought a new DK 35 about a month ago and had the same problem. Couldn't even move the lever at all! The mechanic came out and sprayed the linkages to the transmission with some lube, used a wrench to get the linkage moving and it has worked fine ever since . He said that they get stuck while they are being shipped and have to be broken free sometimes. I sprayed the linkage a couple more times and moved it in and out of 4WD - - no problems.
Good luck with yours,
Reggie
Reggie
Called out the dealer, but got it working before he arrived. It's certainly not convenient after being used to a push-button. Not sure if the tractor needs to come to a stop before operating it (the push button version could be switched in/out at any time).
UNUSED AGT QK20R EXCAVATOR (A51243)
UNUSED AGT QK20R...
Gleaner R50 Combine (A50514)
Gleaner R50...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
2014 CATERPILLAR 306E EXCAVATOR (A51242)
2014 CATERPILLAR...
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
