Oil & Fuel New Diesel Fuel
   / New Diesel Fuel #1
deminin
Central Missouri
Kubota B2910
It is my understanding that starting in a couple of months, Diesel fuel is going to be substantially changed. The refineries, under rulings by the EPA. are going to start supplying USLD (Ultra Low Sulphur Diesel) which contains no more than 15 PPM Sulphur, as opposed to the current fuel which has around 550 PPM. The "impurities" in Diesel are used by current engines as a lubricant, and aid to soot removal. The EPA says that older engines will be able to use the new diesel fuel with no problems. Thats fine....but now we are being asked to Trust The Government, again.
Does anyone have any good info on this new fuel, and any sources for non-government data that refers to the new diesel, and any testing or recommendations regarding using it in older engines. Also, if soot removal might be affected, is there a new grade of engine oil available that can compensate for the changes in the fuel?
I have a super 2002 B2910HSD that I would sure hate to see have problems because of some change in fuel. If I need to change oil, etc., no problem...I just want to be prepared, so I don't have troubles.
   / New Diesel Fuel #2
You might want to ask this question in th Oils, Fuels, and Lubricants forum. Heck, they might already be talking about it and answered your questions.
   / New Diesel Fuel #4
   / New Diesel Fuel #5
deminin:
Mad posted good sources of info. I will add one thing I have picked up and that is the only problem might be with leaks on some rubber parts, but mainly on older machines. Back in the early 90's (maybe 1993) when diesel fuel went from around 2500 ppm sulphur to the 500 ppm sulphur (lsd) that was the majority of problems. Two pluses with this new change: 1. The reduction isn't near as drastic and 2. Manufactures addressed those leakage problems with newer materials and your machine is new enough it should be a problem.
   / New Diesel Fuel #6
New diesel fuel is always better than old diesel fuel....:D
   / New Diesel Fuel #8
Since the new fuel is the only kind I will be able to buy, my plan is to use it.
My only other choice is to let the tractor sit.
   / New Diesel Fuel #10
Ditto here. Except for one addition: I will be glad to use the new fuel, since the refineries will be adding lubricants that won't hurt the environment or my children and grandchildren the way high sulfur would. Bring it on, I say.
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
JOHN DEERE LOT NUMBER 122 (A53084)
JOHN DEERE LOT...
18ft Refrigerated Box for Cab and Chassis Truck (A51573)
18ft Refrigerated...
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2008 AAR MOBILITY SYSTEM REFRIGERATED BOX (A52576)
2008 AAR MOBILITY...
