New Curtis plow
   / New Curtis plow #1
xterra
Bronze Member
Michigan
BX2380
We'll picked up the RTV with the new plow. I must say wow. Better than I thought it would be. Let the snow come!!
   / New Curtis plow #2
Sweet looking rig. I'm with you on bring the snow, I put a plow on my RTV a couple months ago and I'm ready to try it out and see what it can do myself.:thumbsup:
   / New Curtis plow
Now to just learn how to take it on and off if I can remember.:D
   / New Curtis plow #4
Looks like the same plow I have...Haven't used it in the snow yet, my hopes are high though..
   / New Curtis plow #5
Xterra, I have the same plow on my RTV1100 2009 and find it great. Just now getting it on for this winter's use, :thumbsup:as it came off my RTV900 2008 after I traded for the hot/cold air of the new cab.
I bent the skid shoe on one side the second day, trying to plow dirt. Don't do that! :laughing:
And I removed the rubber flap, it made the plow too heavy as I plow on pavement and don't use the shoes at all. It also rolls the snow ahead of you better without the flap. My opinion.
It now has a hydraulic lift which I put on myself and really like that. The electric unit is light and you may find the need to backup when it doesn't want to lift with a lot of snow in front of you.
Swings to a nice angle left/right. Good blade, not commercial grade but seems to be okay for the last 2 years I've used mine.
   / New Curtis plow #6
Spud,
Does you plow have a little slop in it if you shake it front to back?...Put mine on yesterday, and I just noticed it....Might be my OCD:eek:
   / New Curtis plow #7
Tim, not sure which way you mean. Loose in the plate that attaches to the main frame with the two holding bolts or loose in the left/right swing if you move one end front to back. I'll check both when I do put it on.
Later
:thumbsup:
   / New Curtis plow #8
Later
:thumbsup:
Rocking back and forth on the main pivot bolt. There is just an upper plate, no lower...So the bolt is taking all of the hit...Might be cool. Just checking.
   / New Curtis plow #9
That is a very nice plow. Good luck this winter and let's both hope for some snow.
John M
   / New Curtis plow #10
Tim, just checked mine and yes it rolls back and forth too. Not bad though, so I suspect yours is the same. Used it the other day to plow garbage, don't ask, worked great.
:laughing:
2019 KENWORTH T880 (A52472)
2019 KENWORTH T880...
Grundfos Vertical Pump (A50121)
Grundfos Vertical...
JCT Q.A 5' Sweeper (A50121)
JCT Q.A 5' Sweeper...
2014 Jeep Cherokee SUV (A50324)
2014 Jeep Cherokee...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A52748)
Neckover GL24-2-7K...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
