New ct235 leaking antifreeze when using block heater
   / New ct235 leaking antifreeze when using block heater #1
Bobcat racer
Crandon Wisconsin
Bobcat ct235
I bought a new Ct235 paid $15,000 with upgraded seat, block heater, bobtach bucket, and rear work light. When I use the block heater it leaks antifreeze. I can run it for an hour and let it set for days and it won't leak only if I plug in the block heater it leaks. I felt the plug that goes into the block and it was very very hot. Also bought a Bobcat tiller and box scraper. Can't wait for the snow to melt. Called the dealer and they don't know. Any ideas?? Thanks
   / New ct235 leaking antifreeze when using block heater #2
I know my Bobcat CT235 had the smell of antifreeze on it for probably 30 hours from the block heater install. They pressure washed it and I did to, it had to burn off.
When I got home tonight I plugged it in to see if it would leak. Two hours later their was a puddle. Nothing coming out of the plug but I did find the leak. It is coming out of the main hose that goes into the engine on the bottom side. Thanks to those who replied. Can't wait to use it. It's my first tractor. Also bought a set forks. I am glad I found this forum, seems like a lot of info on here. Thanks
   / New ct235 leaking antifreeze when using block heater #5
From your post, it seems as if the tractor has not been run much yet, an probably not worked hard enough to get it up to temperature? If so, it sounds like your lower radiator hose clamp is a little loose from the factory. The block heater is pressurizing the system and is causing the leak. Find the hose clamp and snug it up a bit.
2006 Honda Odyssey Van (A46684)
2006 Honda Odyssey...
2010 John Deere 2305 4WD Tractor (A49251)
2010 John Deere...
42in Hydraulic Forks Forklift Attachment (A49346)
42in Hydraulic...
2012 GMC Acadia SUV (A46684)
2012 GMC Acadia...
2006 Pinguely-Haulotte Star 22J 22ft Manlift (A49346)
2006...
Fuel Tank (A47371)
Fuel Tank (A47371)
