Kernopelli
Veteran Member
- Joined
- Oct 16, 2006
- Messages
- 2,209
- Location
- Carterville, Illinois
- Tractor
- Mitsubishi MTE2000D, Dig It 258 Mini Ex, Deere Z930A ZTR
I had been milking the last out of my old clutch all summer and finally had to bite the bullet and replace it. I split the tractor this weekend and installed a remanufactured unit. Everything went pretty smooth, especially considering it was a first time procedure for me. The clutch works well, i.e....it disengages/engages and I had to readjust the pedal (which I expected) but I had to tighten it up instead of letting it out. It is also takes about 2-3 times more pressure to engage the clutch than it ever did before. It is also VERY abrupt i.e...there is very little "slip" when engaging. I mowed with the tractor about an hour after getting everything back together and it does seem to have "loosened up" a little (easier to slip the clutch /not as abrupt engaging) but still it worries me. I expect everything to work better than before but the increased pressure at the pedal seems excessive. also, the whole time I've been nursing the old clutch I had to occasionally "tighten" the pedal linkage (I assume to compensate for a thinning clutch surface) and to have to tighten it up a lot more after installing the new one seems backwards. I thought I would have to be "loosening" the linkage now since the clutch surface is now at its full thickness.
Any ideas or opinions on this?
Thanks.
Thanks.
