new ck 2510
   / new ck 2510 #1
scrimshaw
florence, wi
kioti ck2510
After reading , lurking and not buying a tractor , I finally pulled the trigger on a ck2510 Hst, with front end loader. ( 14400$) if your curios. Looked at lots of Kubotas , but after reading all the posts here i am expecting to be very happy with my purchase.
I also added a box blade , rear remotes , and filled the tires. I am nit getting it delivered for a couple of weeks so there will be more to tell later. I am mostly going to use it for food plots, fire wood, moving dirt, trails and goofing around. I got sick of a wheel barrow and a shovel. Thanks everybody on this forum for all the helpful posts!:)
   / new ck 2510 #3
Have fun, but be safe.
   / new ck 2510 #4
Congratulations on the new tractor. Make sure you post pics when you get it :thumbsup:
   / new ck 2510 #5
Congrats on the new machine. I bought the same one back in December for about all the same tasks. It's been an awesome tractor and i just hit 44 hours yesterday with no problems so far. I didn't get any remotes installed, but I'm leaning more towards getting a 3rd function or diverter for it on the loader. I only wish it had ssqa on the loader. I am thinking about getting the tires loaded as well.
   / new ck 2510
Will post some pictures when I get it going. I have lots of cleaning up to do after getting a new driveway last fall. I also was hoping for a ssqa, I think the dealer mentioned that could be welded on after if needed. I also may add a mid pto and snowblower in the future if needed.
   / new ck 2510 #7
I bought a new ck 2510 also. I sold my beloved ck20 (1600 hours) along with the rear snowblower. I kept the backhoe from the ck20 and will use it aboard the 2510. I had nearly 1700 hours on the ck20 and I hope this ck2510 is as trustworthy. So far so good. I am really having a great time with the dealer installed cab onboard the ck 2510. The dealer, Michigan Iron di a fine job setting up this ck2510 just as he did 7 years ago when I bought the ck20.
rimshot
   / new ck 2510 #8
Enjoy, Same machine I got last september. No problems so far. Moved alot of snow this year!
   / new ck 2510 #9
I bought a CK2510 back in November.I had a pin hole in the curl cylinder, Dealer got me a new one.My check engine light flashes a code but not all the time on start up.When it does the engine stumbles a little when throttle is moved up. I have 27 hrs on mine.Hope you enjoy it!
   / new ck 2510 #10
I just bought a CK2510HST today with FEL, BH and box blade. Supposed to be delivered next Wednesday. I researched for months and this seemed to be the best bang for the buck. The LS XJ2025 was close but the Kioti had 600 pounds more weight and more comfortable. Really looking forward to putting it to work.
Robert
378747 (A51572)
378747 (A51572)
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
2018 FORD TRANSIT T150 CARGO VAN (A52577)
2018 FORD TRANSIT...
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
