Flail Mower New Caroni TM1900 Flail Mower
   / New Caroni TM1900 Flail Mower #1
nunyabinis
The Outer Limits
Deere
Picked her up last Friday. Finally got to use it for the first time last evening. The height adjusting roller was set on the lowest setting from the factory so I figured I'd see how that worked before I adjusted it. Made for a darned efficient dethatcher since the blades cut into the ground about a half inch!!!
Before I could use it I had to move the tph assembly to the middle position so that the left side of the mower lined up with the outside of the left side tires. The pto drive shaft was six inches too long so I had to shorten it. IslandTractor was kind enough to mail his extra "anti grease burp fitting" to me and I installed it before I fired it up. Thanks IslandTractor!!! Hopefully I can either return the favor or pay it forward one day.
The flail runs very smoothly and doesn't make an excess of noise. Couple that with the eHydro tranny on my 3038e and I can cut my yard in a snap. I am most pleased that it wont take me five hours or more to cut my little slice of Heaven.
One "problem" however: The 3038e has a brake inside the PTO assembly that holds the PTO shaft tight when the PTO is not engaged. I'm used to PTO shafts that you can turn easily by hand to line up the splines with the implement drive shaft. Since I couldn't turn either the tractor PTO shaft or the implement drive shaft by hand to line them up, I had to use a crowbar on the implement universal joint to turn the implement shaft to line up the splines. That is a real PITA!!! Do any of you folks have a Better Way?
   / New Caroni TM1900 Flail Mower #2
I can check mine out later but maybe you can reach under the front skirt and grab a blade and pull the rotor around?? Of course with the engine off and wearing a glove:eek:
What is the 'Burp Fitting'?
   / New Caroni TM1900 Flail Mower #4
Ya know, nunya........... you are supposed to take some pictures to make the rest of us even MORE jealous ! :)
Dohhhhhh!!!!
I'll see if'n I can take some tonight so's I can "rub it in" tomorrow. :D
Pictures!!!!
   / New Caroni TM1900 Flail Mower #7
Now I'm gonna hafta buy one...........................................:(
Thats nice! :)
How do you like the cut?
I like it just fine. This afternoon I mowed several hundred yards of field edge bordering a dirt road. There is a drop off from the field to the road surface that is a couple feet high in some places. Since the mower sticks out about a foot on the right side, I was able to mow right along the edge of the drop off without fear of going over the edge. That drop off has always given me a high sphincter factor. :eek: Not any more!!!
Also, there were numerous sapplings about an inch in diameter growing along the bank and the mower whacked them like they we're there.
So far so good.
   / New Caroni TM1900 Flail Mower #10
Did you just chop saw it to shorten the shaft?? How much did you take off?? I have to do the same with mine....
Nope, couldn't find a better way. Just muscled the gearbox 'til I could find a position that the shaft would mate up with.
Glad to hear you're happy with it!! The little I did with mine a couple weeks ago, I was very impressed!!
-Jer.
Brent 420 Grain Cart (A55314)
Brent 420 Grain...
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
PARTS ROOM W/SHELVES (A55745)
PARTS ROOM...
2017 Autocar Xpeditor T/A New Way 31Yd Side Loader Garbage Truck (A55852)
2017 Autocar...
