New Carbs on E-Bay. ?
   / New Carbs on E-Bay. ? #1
yomax4
Elite Member
Midwest
ISEKI TA 247. Stihl Saws Gravely Zt's Polaris ATV's State Of The Art Welding Equipment
I am thinking of doing a Major tune up on a Stihl 044. I see carbs on e-bay for $30.00. Anyone have any luck with these after market carbs?
   / New Carbs on E-Bay. ? #2
I have had good luck with the carb kits. I haven't bought complete carbs. A buddy of mine in New Jersey fixes a lot of saws and he has used carbs from there with success. Check the sellers rating would not be a bad idea.
   / New Carbs on E-Bay. ? #3
Personally, I would just rebuild the carb you have. All you need is some carb cleaner or brake clean, and an air compressor, and a carb kit.
Might be a little more work, but cheaper. And I just cant imagine that a knock-off carb for $30 is going to be as good as a OEM stihl.
   / New Carbs on E-Bay. ? #4
30mins or less to rebuild the carb from start to finish. Rebuild unless carb is no good. JMO
Carb looks new. I can easily rebuild it. Currently the Hi Lo needles do nothing even after tearing it down and cleaning. Maybe ill try a kit.
   / New Carbs on E-Bay. ? #6
I'm working on a 440 and the carb has stops on it that need removed for getting full adjustments. Does your 044 carb have this on the H and L too?
Nope, I can adjust the H/L and idle. Problem is, Th specs say 1 turn on High and low. No matter where i set them it either wont run, wont accelerate ( bogs ) or screams wide open. Funny though I was cutting big wood and it was 85 degrees out. It has never skipped a beat and I refilled gas and oil and suddenly it ran like stated above. I have 4 Stihl saws and have never had this issue. I ordered a kit for it and i'll see if that helps.
I signed up on the repiar forum you offered. I'll put the kit in the carb 1st and seek help if the kit doesn't help.
Thanks.
Radio Tower Antenna (A47384)
Radio Tower...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2008 Jeep Compass (A50120)
2008 Jeep Compass...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2012 DRAGON 150BBL ALUMINUM VACUUM TANKER TRAILER (A52472)
2012 DRAGON 150BBL...
