jhoward000
Two weeks ago, I bought a new BX2200 with 60" deck and FEL (paid $12,200). I love the tractor, but there is one thing that seems to be a problem, and I was wondering if anyone else has had the same problem, and if so, how it was fixed. Here's the problem:
My PTO selection lever is sometimes impossible to move. I try all the normal tricks, such as turning the PTO, engaging/disengaging the PTO clutch, moving the tractor, and on and on. Sometimes I can park it in this state, try it later, and it works without any effort whatsoever. Not only that, but the position of the lever, when engaged in the various positions, does not line-up with the correct symbols next to the lever. When it is engaged for both the mid/rear pto to turn, it lines up with the mid symbol. When engaged for the rear pto to turn, it lines up with the mid/rear symbol. It will not line-up with the rear symbol at all. Also, the detents for the mid and mid/rear engagements are awfully close together.
There is also a detent in the lever that is between the rear and mid/rear detents. When in this position, the PTO will grind when engaged. There should not be a detent here.
There is no adjustment in the lever or linkag, so the problem must be internal.
I haven't used or played with another BX2200, so I don't know if all of them are this finicky or not. I hope not. I will end up taking it back to the dealer for repair, but I wanted to see if anyone else has had this problem first.
Thanks.
Thanks.
