New BX22: FEL lever locks in the down position?
   / New BX22: FEL lever locks in the down position? #1
JoeCirig
Orange County, NY
BX22, Cub 122 and 127, 3 older than dirt Gravely tractors
I now have 7 (blissful) hours on my BX22 and I noticed that when the FEL is lowered from the raised position, the lever "locks" into place. If pushed forward gently (to lower the FEL) it will spring back to the neutral position when released, but, if the lever is pushed past what feels like a detent, you can let go of the lever and the FEL will continue driving down. This can't be normal?!? I will crush the bed rails of my truck in no time! Anyone else experience this?
   / New BX22: FEL lever locks in the down position? #2
There is a detent that you reach for the "float" feature when you push the lever all the way forward. It will "lock" into that position until you release it. This feature is useful for certain applications, such as plowing snow, etc. You just have to get comfortable with your FEL controls and you'll find that you will not jam the control all the way forward given you know the effect...go practice!!! /forums/images/graemlins/wink.gif
Thanks for the fast reply!
That was probably in the manual/forums/images/graemlins/crazy.gif.
There definitely is a learning curve to using these attachments efficiently.
   / New BX22: FEL lever locks in the down position? #4
The detent is for the float position and it is DEFINITLY normal. To lock your FEL partially up you can make a cylinder lock which will slip on to the rod and prevent it's retraction into the sleeve. For dumping a load of dirt into your truck do not push the lever past the detent but yeah, if you shove it past the detent it will smash your truck quickly. Float is used for back dragging and all sorts of useful stuff and the detent is easily felt so there is no way you could accidently go into float. J
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
2012 GOOSENECK TRAILER MFG.,CO, INC TANDEM AXLE MANIFOLD TRAILER (A52472)
2012 GOOSENECK...
LOT LOCATIONS (A52577)
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2013 INTERNATIONAL MA025 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 INTERNATIONAL...
