New BX On the way next week!
/ New BX On the way next week! #1
AFChief
Hello all. I've just ordered a BX2360 with FEL and a 60"MMM to be delivered next week. What do I need to be ready? I've bought a deisel can and just picked up a Carry-All from TSC. It will be planked and modified this weekend.
Plan on putting her right in the warm shop and put on a coat of wax and silicone on the FEL bucket first thing. Then it going to work!
Recommended tools and supplies to keep the beast rolling?
/ New BX On the way next week! #2
Don't rely on the dealer's delivery prep. Check the fluids!
Congrats! Hope the wait goes fast.
/ New BX On the way next week! #3
Congrats on the new purchase. As Todds112 said, check the fluids. The one area that the fluid will probably be low is the front axle fluid. It may be full at delivery but make sure you check it around the 5 hour mark. The fluid will settle in all the nooks and crannies of the front axle housing, it would be normal for it to be up to a quart low of SUDT.
Highly recommend the Brotek skid plates for your BX http://www.bro-tek.biz. The HST cooling fan is made of plastic and vulnerable to sticks. Also check out BXpanded for all the goodies they sell for the BX.
/ New BX On the way next week! #4
Welcome to tbn . Congratulations on your purchase . If the wait doesn't kill you , you may need another jug of fuel , because you'll find all kinds of projects to justify using that new tractor . That's what its for :thumbsup:
/ New BX On the way next week! #5
Don't bother with the wax and silicone!
Buy a gallon of Fluid Film? | Corrosion Preventative, Lubricant and Rust Inhibitor and brush it in, let it dry one a year over all the exposed painted and unpainted metal to penetrate it and protect it.
and have NO RUST!!!!!!!!!!!!!!!!!!!!
You will be able to purchase it at a JD dealer or E mail Dan for a free sample can.
I can and will assure you that it works and works well for snow blowers and reduces sticking and thats what you want for the bucket on this thing.
About the engine make sure the diesel fuel injection pump is set at zero degrees top dead center otherwise it shakes and rattles at idle and creates a lot of vibration.
They have advanced the timing on the small tractor engines to reduce the NOX and Carbon Monoxide levels and diesel particulates to satisfy the EPA's
crack down on small diesel lawn mowers.
Your tractor will have no difficulty with the injection pump timing set to zero TDC where it is SUPPOSED to be nor will starting at low idle and no higher be an issue as the new settings create huge plume of smoke on some models and you can actually hear each cylinders chugging like a JD 2 lung tractor at low idle.
I dont have any interest in reaching for your wallet, I just want you to be a happy owner and the vibration issue is well known here on the forum.
If they do not reset the injection pump timing to zero TDC you will not be a happy camper.
/ New BX On the way next week! #6
As was mentioned. just check the fluids...Throw a coat of wax on it. This gives you a chance to look over the machine inches at a time......Then go out and GET IT DIRTY:D
Enjoy and congrats!!
/ New BX On the way next week! #7
Congratulations on your new tractor and welcome to the forum; can't improve on the advice given.
Thank you all. I secretly hope some of this snow stays around....
/ New BX On the way next week! #9
Congratulations. So, what are the projects you have planned to do?
/ New BX On the way next week! #10
enjoy your new tractor.
Well, we just moved in to a new place in December. 7+ acres, mostly wooded.
First use will most likely be snow removal (or repositioning :D). Come Spring, I need to move some dirt and level where they had to dig up the septic in the back yard (needed to install a riser to pass inspection).
After that, I'm going to use it to pull out some trees that have fallen and assist in some firewood duty.
Then I want to start to clear some less dense areas in the back. Along with this i want to consolidate a few brush pile for burning.
I have a JD mower, but will use the Bota for the steeper areas near the road.
I'm searching CL daily for a box blade and may invest in a blade of some sort as well. The carry-all will be my wood chopping rig. I may be able to borrow a brush hog from a friend.
That's the plan so far.....
/ New BX On the way next week! #12
congrats on your new purchase. I think a single can of diesel is all you need. those BX's really sips the fuel. When you plan on working in the woods, without the MMM, please consider a belly protection for it. Be sure to post pics of your new toy - opps I mean tractor. :D Like every one says- check the fluids: HST,front axle, engine. You need to grease up all the joints on your tractor so a grease gun is needed. be sure you read your manual on which grease to buy.
/ New BX On the way next week! #13
Seems like you are going to get your use out it. It's pretty exciting for you I'm sure. That tractor you are getting is a little power house. Mine amazed me at what it could do. Have fun and post some pics when you get it.
/ New BX On the way next week! #14
Congrats on the purchase. If you don't have a grease gun I'd get one. I found I needed some of the larger metric wrenches for changing the oil and stuff like that. If you don't do your own servicing, don't worry about it. You might want a pair of axle stands if you take your mower off and store it.
I feel I need to address Leonz post. I've never heard of anyone changing there injection timing on these things??????? I could see that causing warranty issues and its a little bit beyond a new owners ability.
/ New BX On the way next week! #15
Since you don't have your tractor yet, make use of the Search feature and read up on the BX. There is a lot of good information on protecting the belly and tie rod boots as well as maintenance, JOHNTHOMAS put up a really detailed post on the maintenance.
Also watch this a few times.YouTube - Removing a loader from the Kubota BX24
These are great little tractors.:thumbsup:
Will do. I will be doing most of the maintenance myself. As long as it's not more involved than changing a wing sweep actuator on a B-1 bomber!
Looked at the one site with the skid plates, but couldn't figure out how to order/pricing.....
/ New BX On the way next week! #17
I agree with dodgeman. just start out slow and acquire stuff as you go along as your need arise. easier to hide cost from wifey thee boss.:laughing:
As for the TDC timing stuff- perhaps leonz could post a detailed post on how it's done on th BX's with pics and instructions to show the benefits.
/ New BX On the way next week! #18
Congratulations,you'll find all kinds of projects to do after you have it. You'll never lose money as far as investing in buying it.It's like buying a Harley you'll always get your money back if you ever do have to sell it,a long as you take care of it. Again,Good luck.
/ New BX On the way next week! #19
I was just changing a wing sweeper on a B1 last week and wishing I had some help. Does it look like the picture below:)
Now that I look at your name and avatar a little more closely, I'm guessing you work on things a little bit more complicated than a BX.
Used to. Just retired after 28 years. B-1, B-2 and a couple others...;)
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
2016 Ford F-550 Flatbed Truck, VIN # 1FD0W5HT7GEC46417 (A65563)
2016 Ford F-550...
Linx EQ07018RS 18ft Trailer (A65640)
Linx EQ07018RS...
New 1.5x27 Ratchet Strap (A65583)
New 1.5x27 Ratchet...
Hedge Posts (A65640)
44in Single Cylinder Grapple Bucket Skid Steer Attachment (A64553)
44in Single...
