New BX Losing Power
   / New BX Losing Power #1
jadefox
Bronze Member
Rockland, Maine
Kubota BX25D, Case 448
Hey, Guys.
I'm a new BX owner, and I have a brand new BX. I was clearing snow this morning when all of a sudden the tractor began losing power. I put everything in neutral and let it run, and it kept surging and slowing, surging and slowing. I stopped it and checked oil level and coolant level. Coolant level is right at the L line. Oil is fine. Air filter is clean. Any thoughts?
Additional information: It's -4 here. I'd been operating for less than 10 minutes after a 20-minute warm-up.
Thanks in advance.
   / New BX Losing Power #2
Spent a few cold afternoons slurping the fish chowder in a place up to Rockland with my parents over the years. I think is was the Rockland Cafe?
Mmmmm - yum!
Are you using any anti-gel in your fuel?
Try adding some Powerservice or similar if not.
-4 is dernd cold. Almost cold as a witch's ... nose.
   / New BX Losing Power #3
I think your fuel is gelling. Use some Power Service to your fuel. 1 glug per gallon.
Thanks, and, yep, it's dernd cold. :)
The tractor is still on the first tank provided by the dealer, so I have no idea.
+1 on Power Service, eh? Should I check with the dealer first to see if they already added an antigel/winterizer, or does it not matter?
   / New BX Losing Power #6
A double dose won't hurt anything.
   / New BX Losing Power #8
You don't mention the hours but you say it's brand new, so we can only assume very low hours.
The only other thing I can think of is the fuel tank not venting. To check that remove the fuel cap and put it right back on. If the vent is bad you might be able to hear the air rushing into the tank as you loosen he cap.
What about adding coolant? Any suggestions on brands, etc.? All of got in the barn is some Napa antifreeze/coolant my wife has for her car.
Under 5 hours. I'll try the venting as well. Thanks.
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A50322)
2017 Caterpillar...
2001 Volvo VNL Truck, VIN # 4V4N19JF51N250353 (A51572)
2001 Volvo VNL...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2008 John Deere TX 4X2 Gator (A50121)
2008 John Deere TX...
2013 Ram 4500 Versalift Bucket Truck (A50323)
2013 Ram 4500...
John Deere 3pt 7' Mower (A50121)
John Deere 3pt 7'...
