New Bush Hog setup?
/ New Bush Hog setup? #1
willy1947
Solsberry, IN
Kubota L3830 GST
I just bought a brand new King Kutter 6' rotary cutter from tractor supply. I know I have to service it, grease it, and fill with fluid. Is there anything else anyone suggests I do while preping it for use or to help maintain it?
I'll follow the assembly instructions, but just wanted to know if anyone thought of any other break in procedures.
Thanks,
Dave
/ New Bush Hog setup? #2
</font><font color="blue" class="small">( just wanted to know if anyone thought of any other break in procedures.
)</font>
Make sure to take it and chop the tops off of some large rocks the first time you use it. No sense putting off the inevitable. /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
/ New Bush Hog setup? #3
No breakin procedure needed. Just fill the lube, grease the fittings, hook it up and go. You may need to adjust the rear wheel to get the desired cutting height. With the rear wheel on the ground, adjust the 3ph so that the front of the deck is slightly lower than the rear of the deck. That will give optimal cutting performance.
Then it is just periodic maintenance, checking fluid level, greasing the fittings, and sharpening the blades. And maybe straightening some metal or doing some welding if you hit something or back into something you shouldn't. /forums/images/graemlins/blush.gif
/ New Bush Hog setup? #4
Make sure the driveshaft is not too long or short!
/ New Bush Hog setup? #5
willy,
If you haven't attached/detached 3 point hitch implements much, this <font color="red">thread</font> might prove useful. The sequence for attaching is just the opposite of detaching.
Otherwise, as already posted, once greased and filled with fluid, your cutter should be ready to go. Enjoy!
OkieG
/ New Bush Hog setup? #6
<font color="blue"> "once greased and filled with fluid, your cutter should be ready to go" </font>
You'd think so, wouldn't you? /forums/images/graemlins/confused.gif
One additional thing I had to do with my KK rotary cutter was loosen the bolt/nut assembly on the rear wheel and grease it so it would turn. They are shipped by KK with the wheel intentionally tightened so as not to turn in order to facilitate loading and unloading.
I'd love to tell you I learned that BEFORE I made a nice trough through the grass. /forums/images/graemlins/shocked.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/smirk.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/grin.gif
/ New Bush Hog setup? #7
<font color="blue"> I'd love to tell you I learned that BEFORE I made a nice trough through the grass </font>
Gary,
Seems like the lessons we learn and remember are almost always learned the hard way.
OkieG
/ New Bush Hog setup? #8
</font><font color="blue" class="small">( I'd love to tell you I learned that BEFORE I made a nice trough through the grass)</font>
Don't feel too bad about that.. i joined that club as well.. the first day I had my mower...
Soundguy
2025 GRIFFIN DUMP TRAILER (A59910)
2025 GRIFFIN DUMP...
2023 Chevrolet Express 2500 Cargo Van (A61568)
2023 Chevrolet...
UNUSED ATS EPC40 ELEC.PLASMA CUTTER (A62131)
UNUSED ATS EPC40...
UNUSED KJ 23'X22' DBL GARAGE METAL SHED (A62131)
UNUSED KJ 23'X22'...
2018 Land Rover 4WD SUV (A61569)
2018 Land Rover...
BUNDLE OF APRROX (20) 3'X30' METAL SHEETS (A62131)
BUNDLE OF APRROX...
