Samandothers
I have a Bush Hog SQL-160 that I run with my Kubota.
When attaching the drive shaft from the Bush Hog to the PTO on my Kubota I have to slide back a collar on the end of the drive shaft as I slide it up on the PTO. This allows the splines to slide up on the PTO. When the 'ball' aligns with the trough in the PTO the collar is released and holds the 'ball' in the trough so the drive shaft will not back off.
My brother has an 8N. We would like to use the SQL-160 with the tractor. He has a PTO mounted clutch (for over run) used with the 8N and an older model Bush Hog back in the late 60's early 70's. The clutch requires a sleeve to 'enlarge' the splines so the Bush Hog drive shaft will fit tight on the clutch. The problem is a pin is required to lock the drive shaft to the clutch. The SQL 160 drive shaft has the collar and ball arrangement and no hole for a pin.
What is the best fix? New clutch, different drive shaft for this tractor? I am open for suggestions.
Thanks for some input!
