New branson 3510i - Leaking Hydraulic Pump
   / New branson 3510i - Leaking Hydraulic Pump #1
redfoxco
Branson
My new branson has approximately 10 hours on it now and the hydraulic pump is leaking from what appears to be the pump body seals, not any of the low pressure (return) hoses associated with the pump.
It has developed a big enough leak to drip a small amount of fluid on the garage floor.
Is this a common problem and is there a fix? /forums/images/graemlins/confused.gif
All the bolts seem tight.
Thanks.
   / New branson 3510i - Leaking Hydraulic Pump #2
You should contace your dealer and have it fixed,It is not common to have a leak,possibally a bad o-ring or seal
Will do. Thanks.
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
STORAGE FEES (A52576)
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
Skid steer auger plate (A50322)
Skid steer auger...
John Deere 6120E (A50323)
John Deere 6120E...
