New Boomers
   / New Boomers #1
MackAttack
Central NY
NH TC35D
My dealer has a bunch of the new Boomers in stock. I got to look under the hood of the a new TC35DA & TC45Da.
They look as if they corrected some of the issues we posted here such as the leaking battery problem (they have a battery cap with a hose that runs through a hole and out the bottom of the engine compartment)
They changed the light headlight switch to a heavy duty big dial setup with four positions on it. This looks as though it would keep water from getting into the switch which could freezing.
They also put different pins on the rool bar with cables attached so that you can forget about losing your pins and rods.
New grill and headlight setup. The lights now go vertical up the front corners instead of horizonal across the front. I Think that this may work better with the FEL.
The gauges are more finer or precise looking, though they could be harder to view for some of us they may be a benefit to others. Looks like there may be more indicator or idiot lights.
The only thing that I do not like about the new set up is the hand rails on the fenders. Though they look better I do believe they take away some of the support from the fenders. I could move the fenders slightly back and forth and wonder if they will shake while the tractor is running or working. I tried to move the ones on my TC35D and they are quite solid compared to the newer style.
I also noticed that the hood latch seems to be a little thicker and longer comp[ared to mine.
Overall the rest seems be the same tractor with some cosmetical changes.
I wish I could afford a new one but my money has elsewhere to go.. New barn, vehicle, wife etc. etc.
Hopefully I can establish a new vehicle and tractor replacement plan-buy one pay it off then when one is paid off keep it awhile then trade the other in and pay that off etc. etc. Cold in Central NY
   / New Boomers #2
I saw a TC55A at my dealer not long ago. While its really nice I wondered if a utility tractor wouldnt be better and cheaper(?). So, why would you buy a class 4 Boomer instead of the TT or TN?
   / New Boomers #3
Hmm.... ROPS pins with keeper cables.. what a novel concept /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / New Boomers #4
</font><font color="blue" class="small">( So, why would you buy a class 4 Boomer instead of the TT or TN?
)</font>
Maybe because the TN55 is going away. That's what my dealer told me. /forums/images/graemlins/smirk.gif
   / New Boomers #5
</font><font color="blue" class="small">( </font><font color="blueclass=small">( So, why would you buy a class 4 Boomer instead of the TT or TN?
)</font>
Maybe because the TN55 is going away. That's what my dealer told me. /forums/images/graemlins/smirk.gif )</font>
There's been a big hole in the New Holland lineup for a couple of years ever since the 2120 was discontinued. On paper the 2120 had less hp than the TC45, but it was a considerably larger frame and could carry more serious implements. The TC48 and TC55 are 2120 replacements. They are considerably larger than a TC45. I have both a TN75 and a 2120 and they are very differnt size tractors. The TN just won't get into arears where the 2120 will. By the way, the 2120 was one of Ford / New Holland's most popular models and dealers put a lot of pressure on New Holland to replace it.
Andy
Takeuchi TB260 (A50120)
Takeuchi TB260...
2014 Chevrolet Impala Limited (A50120)
2014 Chevrolet...
RV Hitch (A50121)
RV Hitch (A50121)
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
PT Spray Rig (A50121)
KJ 33'x25' Double Garage Steel Barn Shed (A50121)
KJ 33'x25' Double...
