Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,424
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Well.. I'm getting pretty good at changing fuel line O-rings on my tractor.
Here's how my day went:
It has been raining in florida just about every day this month. Grass is a mile high.. I've been working doubles for weeks and had no time to mow.
I got off work at 3pm today so I could run home.. feed the animals, and hop on the tractor and lay down about 10ac of blacktops.
Here's where it turns sucky... 3:30pm.. tractor won't start.. battery dead. I hop on my 12v converted 1954 NAA and it of course fires on the first start after setting nearly all year.. even with old gas... I drive it over for a jump... nada...
Ok.. clean the terminals.. .. now battery will make an impressive click at the solenoid. Hygrometer tester shows bad cell in battery.. Oh well.. it is 3ys old? /forums/images/graemlins/mad.gif
Off to TSC.. NO battery for my tractor ( NH 7610s ).. off to NAPA.. they have a battery that is darn close.. I get new cable ends and all the goodies.. felt washers.. cleaner spray.. protector spray.. etc.
It's now 5pm.. new battery is in.. cranks over like a champ.. but won't start? /forums/images/graemlins/confused.gif /forums/images/graemlins/mad.gif
I start searching around... find 3 rats nests.. one by radiator.. one under hood on head.. one behind dash. 1 chewed wire.
Fix wire.. tractor starts.. runs for 30 seconds then stalls /forums/images/graemlins/confused.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/mad.gif
No fuel att he bleeder.. no fuel at the filter fitting. Plenty of fuel out of the valve opening at the petcock.. just none out of the line from the petcock..
I replaced this line 6 weeks ago and put in new nitrile orings when I did it..
I pull it apart...and find that the oring got soft and bunched up in the front of the hard line. Oring did NOT look like nitrile.. but like plain old rubber... /forums/images/graemlins/mad.gif
I grabbed my oring picks and my assorted packs of buna-N and nitrile orings.. found a few to match up and thru it back together... had great fuel flow.. I wiped it all down.. let it run for 15 minutes.. ran great even under load.. no leaks.. It's dark now.. 8:30pm.. I see a faint spark under the hood. /forums/images/graemlins/confused.gif
Pop the side hood, and find a single strand of copper wire missed the battery end and was sticking straight up.. like an inch.. and was just enough to make contact under the hood /forums/images/graemlins/tongue.gif
I cut it off, and then for added safety.. cut up an old tire innertube and made a blanket for the top of the battery..
Oh and I set out a pack of yummy rat poison in the places I found the nests.
As I was putting my tools up I could see the furry critters scurrying around the tractor... I hope they eat their fill tonight! /forums/images/graemlins/ooo.gif
It's like 9:15 now.. I got -0- accomplished and took off work to boot /forums/images/graemlins/tongue.gif
Havn't eaton... and am a bit grumpy.... I'm glad the days almost over...
I think the worst part is that this ^%# 24,000$ tractor is working me to death to use it.. yet my antiques seem to keep on going.. and going... with less hassles...
And what's with that bogus oring!!?!?!?!
Soundguy
Soundguy
