New Beaver owner with questions
   / New Beaver owner with questions #1
ssg510
Hey Guys. Im new and have been following the forum for awhile. Just picked up a beaver s370d. Great shape but was left outside for some time. Im going to change all the fluids and need some help. What do you suggest when changing the hydro/trans fluid. As is typical, my fluid is the color of coffey with cream in it. How do I flush it or do I need to. I picked up the Aw 46 fluid from tractor supply. Any suggestings on the process. Also located a koyker 110 fel for a sweet deal. Will it fit my tractor. This is a great forum and I look forward to participating. Looks like alot of great information from nice people. Thanks
   / New Beaver owner with questions #2
Use "JD303" type hydraulic/trans oil. It is a very common type of oil.
To flush, I wouldn't hesitate to use diesel or kerosene. Others will say to ATF. Either way it should be flushed. Clean the pick up screen too! Be careful with the loader unless it has a subframe to fit your tractor
Thanks Alvanko. Silly question but how would I "flush" the system. Do I just fill and operate the system a few times or what. thanks
   / New Beaver owner with questions #4
Valley Power
just drain the reservoir,clean the screen,fill up and use all the controls back and forth a few times then drain,, clean screen and refill again.
thanks. Ill give it a try
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A54757)
UNUSED WOLVERINE...
2011 NISSAN FRONTIER EXTENDED CAB TRUCK (A51247)
2011 NISSAN...
2019 Chevrolet Suburban (A53424)
2019 Chevrolet...
UNUSED IRANCH EXCAVATOR ATTACHMENT SET (A54757)
UNUSED IRANCH...
2022 FREIGHTLINER CASCADIA SLEEPER (A54607)
2022 FREIGHTLINER...
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
