New battery
   / New battery #1
coolbrze
VA
Kubota MX5800
I just purchased an older model used Yanmar FX24D that came w/ a Rural King HD battery P/N: CFT31X4 (925 CCA @ 0ー F & 1,050 CCA @ 32ー F) that seems to be dying. I need to replace the battery, but not sure if I should replace it w/ something similar or something else, what do y'all recommend? Thanks!
   / New battery #2
I've started converting to AGM - they seem to have a much better performance - My Jeep actually came OE with an AGM and it's now over 3 years and still cranks like the day I bought it. The downside is they are EXPENSIVE but if you really rely on something starting when needed I'm a firm believer, plus they are essentially zero maintenance sans making sure the terminals stay clean (which because of very little venting they do).
I've got a relationship with our local BatteriesPlus thru our local fishing club and got to know the owner of the franchise, he's been a great guy (as have all his employees) to work with, the employees are well trained, and when I've had warranty issues they have taken care right away. Yes, all manufacturers have defects occasionally, it's how the retailer takes care that makes the difference. The other advantage to AGM is they are much more vibration tolerant.
Now, if you're just playing w/ this as a hobby, you might be better suited to a Walmart battery, they actually are very good for a conventional lead acid wet cell and priced extremely competitive. What ever you choose, try to buy the largest CCA that you can physically fit in the space correctly (meaning firmly attached and restrained from movement). There is no such thing as too big a battery (within reason) meaning don't let someone tell you that you should match what is there, if you can fit more CCA go for it, it means easier starting when cold. Your charging system will most likely charge anything you can fit in the space if it's in good shape.
   / New battery #3
In the past I always bought Interstate batteries.
Never again! They stiffed me for what should have been a warranty replacement, while I had my vehicle in Canada.
The AGM batteries certainly are excellent, for the reasons described above.
Bottom line though,....... Walmart batteries are definitely the best bank for the buck,
   / New battery #4
I'll never buy a interstate battery, bought one last year started to leak around the negative post, took it back to the guy that installed it he said interstate wouldn't warrant because it still had 85% charge. My first and last interstate battery. It's all about the marketing.
   / New battery #5
Use biggest battery that will fit in the box, of whatever brand..
   / New battery #6
oh boy. I JUST last week bought 2 Interstate batteries for my Ram truck...ha, guess I'll wait and see how my luck turns out. Like others, go with an AGM.
   / New battery #7
Battery failure could be due to under charging, over charging or a phantom load causing discharge . Putting around tractors rarely have their batteries properly charged.
Use the largest battery that will fit into the battery box. Use a new large ground cable direct from the battery to one of the bolts holding the starter to the block.
   / New battery #8
Interstates have gone down hill. I had one go out in 3 years on my sequoia. This is the wife's daily driver. We have had it 3 years I guess now. Battery was a year old when we got it or so. It was always kind of weak. I didn't fool with pro rate warrenty because I didn't want another one and I didn't buy it originally. I use to buy walmart then switched to advance e auto batteries and used online coupons to buy online and pick up in store. But they have recently raised their prices ...really high and even with these $30-40 coupons when you find them there still barely competitive. I went back with walmart batteries this go round. I always had success with them, I just swapped due to price. I had one or 2 walmart batteries go 7 years. Tip if you buy the cheap walmart batteries there is no prorate period, so once your out of the free replacement zone that's it...that's another reason I went to advance. But I noticed ,I think (would have to double check) on the 3 year free replacement battery there is a pro rate period also.
And I also would give the advice. Put the largest battery you can fit in the place.
   / New battery #9
That's what I tend to do. The one the OP has now seems to be high on cca 925/1050. That thing when good should turn over a Mack truck.
   / New battery #10
I also buy the biggest that will fit. I've found the better deals at SAM's club with the 3 year free replacement .
2014 GALYEAN 180 BBL STEEL VACUUM TANK TRAILER (A52472)
2014 GALYEAN 180...
Steiner Front Cut Mower (RUNS) (A50774)
Steiner Front Cut...
PENDING SELLER CONFIRMATIONS (A52577)
PENDING SELLER...
Trail-Sport TS21RBH RV (A50121)
Trail-Sport...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
