new alternator, now won't start
   / new alternator, now won't start #1
stuwik
Replaced the dynamo in my B7610 HST. Put in a 40 amp alternator kit which I purchased from dealer. Followed instructions to install. Now the starter cranks the engine just fine. However, the engine will not catch and run. I am getting ready to uninstall and put dynamo back in, just to see if it starts. Prior to alternator installation, no problems of any kind starting, electrical or anything else. Battery is strong. Any ideas? Thanks
   / new alternator, now won't start #2
Check your fuses.
   / new alternator, now won't start #3
Try fuses as suggested to se if any have blown.
I'd re-check your installation. If starter is turning then the bat terminal seems right.
You might need to look at only the other wiring as you may have wiring going back to the fuse box mixed up - just on the wrong terminal at the back of your alternator.
Also, are all your instruments working & are they working correctly?
   / new alternator, now won't start #4
does this have a key-off fuel solenoid and/or an electric fuel lift pump?
soundguy
got it started...plugged original relay back in to original harness. Also plugged new relay into new harness. This allows some kind of a solenoid,fuel switch ?? something that creates an obvious click when key is turned on. Charging at 14.6 volts, thanks for replies.
   / new alternator, now won't start #6
glad to hear.
soundguy
   / new alternator, now won't start #7
Good work mate!
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
Electric Forklift Pallet (A50322)
Electric Forklift...
40' CONTAINER (A51244)
Case Maxxum 140 (A50120)
Case Maxxum 140...
