New 7610 - initial comments and questions
/ New 7610 - initial comments and questions #21
unless I am missing something, my new 7610 doesn't have any armrests. Maybe the dealer didn't send them. HA
Donald B.
/ New 7610 - initial comments and questions #22
I know I'm kind of jumping on the thread late...but the funny thing is I have used my B2910 A LOT...REALLY A LOT... and the hour meter just passed 315 on the B2910.
Now the little bx...well I have not used it that much but already it has almost 50 hours on it!
Linerar time sure goes by faster than tachometer time!
As far as seat time I suppose with both I get about 8 hours seat time for each five gallons of fuel used... /forums/images/graemlins/smile.gif
Guess gallon per seat time hour must be the true measure.... /forums/images/graemlins/cool.gif
Burk - it is also difficult getting the mid pto in gear, but seems to be getting better.
I now have 5 hours on my 7610. My dealer said to go ahead and run at 2400 rpm and we tried it today. The blade lift definitely seems to be better.
My wife got to use it this evening, and had a big grin on her face /forums/images/graemlins/frown.gif I can tell that she is going to want her share of seat time!
The dealer has not been out yet to check out my hydraulic issues. The only day that worked for me so far didn't work for them!
Do you guys typically mow in hi or low gear? We like the speed of hi, but you really get bounced around more than my old 445. It must have something to do with the longer wheelbase.
Regarding the meeting in Grove City next month, I keep on forgetting to ask the boss to see if anything is going on that weekend. It seems that every weekend has a niece/nephew birthday or some other "important" event! If nothing is going on i'll try to make it.
/ New 7610 - initial comments and questions #24
"Do you guys typically mow in hi or low gear? We like the speed of hi, but you really get bounced around more than my old 445. It must have something to do with the longer wheelbase. "
No, the bigger tractor has a stiffer ride, my 2410 rides harsher than my BX. It is those R4 tires I think.
I mow in high range but not with the pedal down to the floor /forums/images/graemlins/crazy.gif. I mow at 5 MPH or so, maybe 6 on smooth ground--well below top speed. If you are careening around at full speed no wonder it rides rough /forums/images/graemlins/shocked.gif. If you want to mow at that speed you should have gotten a Hustler Fastrac etc. Hmmmm. J
Actually, my wife and I both feel that mowing in low gear is a more enjoyable experience and provides better results. We just noted that the 7610 was much harsher than the 445 when pushed.
We thought about getting a ztr quite a while ago, but was not the casual and laid-back mowing experience that I enjoy. I spend all day dealing with frustrating employees, clients, contractors and phone calls and need a break. For me, mowing with a tractor does that. Plus, the ztr's ride was absolutely horrific at fast speeds! Hehe, maybe I need to be better about rolling the lawn!
It certainly makes sense that frame stiffness is more the cause of this than wheelbase differences.
/ New 7610 - initial comments and questions #26
"It certainly makes sense that frame stiffness is more the cause of this than wheelbase differences."
I know little about the JD 400 series tractor styled lawn mowers as to frame stiffness. I do know the BX is at least as stiff if not stiffer than my 2410 and the 2410 rides rougher. I figure, like I said, it is the R4 tires. They will stand up even with the air out of them. Inflated they are not much different than having a steel tire like old time tractors had /forums/images/graemlins/tongue.gif.
If I tried to mow this place in low range I would be out there till the cows come home and died. J
I should have mentioned this in my last post, I have turf tires on my 7610 not R4's.
/ New 7610 - initial comments and questions #28
My experience with my B7500...
- Mow in Low, pedal to the floor.
- Keep RPM's at lowest when engaging PTO, then throttle up after PTO is engaged.
- "Double-Clutch" prior to engaging Mid PTO, and push on lever just before bottoming out tyhe pedal on the second push... It'll slide right in.
/ New 7610 - initial comments and questions #29
Mowing in low is way too slow.....
For me anyway.... The beauty of the hst is to speed up through the straight smooth areas and slow for turns, obstacles and other things needing slower speed.
/ New 7610 - initial comments and questions #30
</font><font color="blue" class="small">( I should have mentioned this in my last post, I have turf tires on my 7610 not R4's.
)</font>
Then I expect it rides easier than mine but nonetheless if you go fast it is going to bounce. I think the turf tires have more bounce to them, the R4s have a stiffer ride. Try adjusting your air pressure and might consider getting them filled. I would just slow down. J
/ New 7610 - initial comments and questions #31
My dealer checked there is an armrest option for the 7610. My seat is drilled for one. I thought they might fit.
I mow in high in the open fields and low range when I get to the hills and springs.
Follow up to my original post.
I now have 12 hours on my 7610. It took a while (the dealer missed appointments twice before finally getting the tech to my house) but I finally had my tractor looked at by the dealer. It turned out that the hydraulic fluid is low because of a leak in the factory connections where the loader's piping attaches to the tractor. Evidently there is an o-ring that needs to be replaced. The fluid was very low, didn't show up on the dipstick. I mowed for 2 hours like this before the dealer came over. Do you guys think that anything may have been damaged?
When full with hydraulic fluid, the steering is much better but the deck still drops but very slowly. The dealer adjusted the 1/4" valve and says that the valve does not raise the implement the same way as it lowers it. They told me to ease the control lever back very slowly if I want it to rise slowly. This seems to work, but i'm wondering if you guys experience the same thing.
I'm loving the loader. I've probably used it 4 hours so far, spreading mulch, moving firewood, moving dirt and ripping out several huge jagger bushes.
I've tried to mow my field with the loader, but definitely do not like having to worry about the extra length. The tractor maneuvers so much better with it off.
Yesterday, I really ripped the lawn up. Previously, the only place I noticed damage was when I did a circle around trees but yesterday it was everywhere! My wife was nice and didn't say a word. It turns out that I mowed in 4-wheel drive! Even in 2-wheel drive, this tractor takes much more care than my old 445 to avoid damaging the lawn. Im not used to it yet, but am going to have to figure out a way to change my mowing pattern.
Once again, I whacked the shed with the ROPS. Hopefully i'll get used to it soon.
Regarding cut quality, it seems that it cuts better the lower the deck is set. Even with the deck low, I noticed a high area where the front tires went over the grass. I'm assuming that suction is better at lower heights and am considering getting hi-lift blades. Have any of you tried hi-lift blades on the 7610? The 7610 cuts hills much better than the 445 due to the deck being supported from the ground. The suspended deck on the 445 always used to cut the high side of the deck high and the low side low and created a "tiered" effect.
/ New 7610 - initial comments and questions #33
You might want to learn how to check the oil, kinda important. I would'nt worry as long as it is operarting correctly now. You should check fluid levels everytime you use the tractor or at least on a regular basis. How come you did not? You expected it full from the dealer? This is kinda like flying, I told the line boy to fill the tanks--zoom-ka-put-ka-put--CRASH, guess I should have looked myself. J
Yeah, I did expect it to be full. In fact, I complained quite a bit to the salesperson and made it very clear that his tech was in error.
However, I was also in error expecting the dealer to setup the tractor properly and not verifying.
Subsequently, I have gone over everything step by step using the startup procedure in the Kubota manual.
/ New 7610 - initial comments and questions #35
Well, you have learned a valuable lesson and fortunately got off with no damage to your machine. Good luck. J
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
2005 Trail-Eze TE70HT53 42 Ton Hydratail T/A Drop Deck Trailer (A61573)
2005 Trail-Eze...
2014 Wanco FD-304 Folding Solar Towable Arrow Board (A61572)
2014 Wanco FD-304...
1985 23ft Mako Center Console Boat with 2011 28ft HMDE Trailer (A61574)
1985 23ft Mako...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
Challenger MT800 Series Service Manuals Vol. 1 and Vol. 2 (A63117)
Challenger MT800...
