New 4500P Review
   / New 4500P Review #1
Farmerboy
Bronze Member
Parker, Pennsylvania
Mahindra 85 / Ventrac 4500P
Machine = Ventrac 4500P
Engine = Kawasaki 31HP Digital Fuel Injection ("P")
Optional Foot Pedal
Optional Arm Rests
Dual Wheel Kit
Tough Cut Mower Deck
72" Side Discharge Finish Mower
Reason For Purchase: my wife and I maintain a 300 acre farm in western Pennsylvania with slightly more than rolling hills and a few swampy areas. Despite having a large Ag tractor with 8-foot brush hog, a walk-behind 24" brush hog, two gas powered trimmers with blades, and a 55" Ferris zero turn mower, there are several areas of the floor that were either not maintained or were very time-consuming and difficult to keep up. After very little searching, and a site demonstration by a local dealer, we made the decision to purchase the above identified machine.
Initial Feedback: Wow. There's not much else that needs to be said, but I will elaborate. The tough cut deck does a fantastic job of plowing through everything from thick wet grass 2 feet tall to thick brush. The quality of the cut is much nicer than a standard brush hog. As well, the deck does a great job of chewing up material and spitting it out the back.
The finish mower is just amazing. We do not have a traditional "lawn", but rather have a yard that was reclaimed from an old pasture field and never reseeded. After 3 mowings, our yard looks like a cross between a ballpark and a golf course - nicest the farm has ever looked.
Behind our house is a very steep hill (35-40 degree range). This area has typically been maintained once per year, and usually grows back thick with blackberry bushes, raspberry bushes, and other wooded vegetation. Over the course of the past three years, grass has gradually come on. After mowing the area once with the tough cut deck, there was a world of difference in the appearance. I subsequently cut the hill with the finish mower three more times. It looks simply amazing. So much so, that I've had complete strangers stop and ask how I cut the hill.
And of course, where you have steep hills on one end of the spectrum, you generally will have swampy areas at the other end. Traditionally I have cut cat tails out of a swampy area by hand once every year or two. Simply because of the amount of transient water, I do not use the Ag tractor to brush hog, but will cut it by hand (don't want to bury the tractor up to the axles in mud). I got a little adventurous with the new machine, and was able to flat out cut what normally would take two full days in about 45 minutes. I don't need to say anything else about that.
I've also moved around a hay rake and utility trailer using the rear hitch.
I could go on singing the praises of the machine, but I won't. If you have any specific questions about any of the equipment listed above, I would be happy to address them as they arise.
Optional Arm Rests = worth the money. Get the stardard seat with optional armrests and you will not be disappointed.
Optional Foot Pedal = I guess it's ok. The fact is the footpedal is pretty useless for driving the machine when mowing. It is somewhat hard to manipulate, and quite frankly is awkward when the tractor is articulating. With that said, if you want to carry a gas can or a weedeater or anything small, you can't. You need one hand to drive the SDLA (throttle) lever and the other hand to turn the steering wheel. That is where the foot pedal comes in handy as it frees up a hand to carry an object.
Objections: Despite the fact that the machine is very capable, there are a handful of things that I do not care for. In no particular order:
1. I don't care how many YouTube videos I've watched, or how easy it appears in the Ventrac marketing material, I have thrown fits trying to switch between the two mower decks; lost all kinds of religion switching decks. With that said, it does get easier with more practice, but is still not as easy as it would appear in the Videos. Keep in mind, this is also from someone who is very familiar and experienced hooking up agricultural implements.
2. This machine doesn't sip gas - no, she's a hungry ***** that has earned the nickname Fat Jenny. The 4500P probably burns the 1.2 gallons per hour in accordance with specifications. However, it seems like I am constantly filling it up. Of course, when you put nearly 50 hours on the machine in only five weeks, you will have to feed it. I'm making this point simply to highlight the fact that the other machines (Kubota in particular) must really burn fuel - so, you're going to need a few 5 gallon gas tanks.
3. My machine came new from Ventrac with a hydraulic fitting in the steering system that was not tight. I took the time to remove a few panels and snuggle everything up, which stopped the leak. However, this was not before hydraulic fluid leaked all over the garage floor and adjoining apron. I hate hydraulic leaks - let alone in a new machine.
4. Doing the service work requires a little bit more thought and ingenuity. For example, because the frame is so low to the ground, I could not get a drip pan under the oil drain. I ended up just driving the machine onto a set of 2 x 4's to lift it off the ground high enough to gain clearance. As well, unthreading screws and removing panels takes a little bit more time than I am accustomed to from other machines. Not really a big deal, but something I have not encountered in other equipment.
Punchline: Absolutely amazing machine. When considered in hindsight, I would absolutely purchase again without a doubt. My wife enjoys running this machine, I enjoy running this machine, and our property looks amazing. The final out the door price was almost $30,000 exactly, and I would absolutely say the machine was worth every single penny. The 4500P is very capable and well powered. From a safety perspective, and from someone who has rolled over a tractor, I have no reservations about my wife operating this unit on steep slopes. I have zero reservations about this machine's capability.
Again, if anyone has any questions about the equipment, or anything stated in this review, I would be happy to add additional details and explanations. As well, if you are interested in a perspective from a first time Ventrac buyer/owner/operator, I would be happy to share my experiences and decisions with you.
   / New 4500P Review #2
You are right on hooking up, but I beat that by disconnecting the seat switch so I can hook up from beside the machine. The fuel thing, I find it easy on fuel I cut steady and wide open up and down hills for 3 hrs. but with a 60" mower on less than 4 gallon. I am in total agreement on greasing and changing oil it is a pain. having to remove panels for greasing and changing oil and wait till you try to grease the drive shaft is not like the videos. I ended up drilling a hole in the side to get on the front u joint. For what you pay you would think a little more thought would have went into it. If you have the new deck that takes the tilt cylinder better check the grease fittings on the spindles. they were loose and I lost one cuttings cleaned it out and replaced the grease fitting. the counterbore is too small to get a socket on. So I had to grind the socket down enough to go in the counter bore to tighten the grease fittings....... Jim
   / New 4500P Review #3
Make sure the weight transfer is set to its lowest setting when changing implements.
   / New 4500P Review #4
Yep, Ole Saint Pete might have some stern looks for me regarding my Ventrac attachment language back when I was green at this. I, too, am very experienced with larger tractors and implements. Murph's observation above is helpful. When my tough cut mower is on its support stand, it is still too low to allow me to just pull forward into it. So I put the lift arms a bit low, drive in until resistance and then lift slightly to align the latch parts. Like johara, I sometimes cheat and attach off saddle; my method is to pull the park brake back one click at a time until the little red dash light comes on and no more. At that setting, I can move the tractor from the side. It may not be safe, but going insane from not being able to see is not safe either.
When my 4500Z was new it was a real fuel guzzeler. I think breaking in helped a little and correcting a dealership problem (spark plugs were severely damaged by corrosion) helped a lot. Now it seems to be on par with other reports we see for gassers. I did purchase lower profile catch basins for motor and hydraulic oil changes.
prs
   / New 4500P Review #5
I found when changing oil and filter a cheap throwaway pan to do a large turkey slides under the machine and will get the oil from both the filter and the drain plug. Only a couple of qts. then dump into a container, saves a lot of mess....... Jim
2011 INTERNATIONAL PROSTAR SINGLE AXLE DAY CAB (A43003)
2011 INTERNATIONAL...
John Deere 5105 Tractor (A41660)
John Deere 5105...
2020 KENWORTH T680 HIGH ROOF SLEEPER (A43004)
2020 KENWORTH T680...
New/Unused 2025 MX-CRT23 Mini Skid Steer (A44391)
New/Unused 2025...
CP 12in Excavator Bucket (A44391)
CP 12in Excavator...
2020 KENWORTH T800 T/A DUMP TRUCK (A45333)
2020 KENWORTH T800...
