new 4320
   / new 4320 #1
buckmaster
illinois
just purchased it with R4's-loader-forks-mx6 cutter. Ne with tractors so an advice on how to brak in woudbe great. Have a 110 acres of deer hunting land that has food plots ad have been maintaing with atv but it is too much now. Any help would be great.
   / new 4320
sorry about the spelling. New at this
   / new 4320 #3
<font color="blue"> ( sorry about the spelling. New at this ) </font>
Welcome to TBN.
When you make a post, the EDIT link is active -- and you have about 12 hours to make edits to your post if you find you have spelled something wrong, or forgot to add something, etc.
Check your owner's manual for the proper break-in procedure.
   / new 4320 #4
I have the 4720 with MX-6, and find that if you can drive over it with the FEL, the cutter will cut it. I have been using it to cut 2" maple trees that had grown up over a five year period in some fields recently purchased.
All I can suggest, is keep moving forward and avoid backing up, the brush/trees will not catch anything while moving forward on the 4X20 tractors, but if you back up, several things are exposed to damage.
Enjoy,
James
   / new 4320 #5
You will enjoy that combination.
I agree with the 'not backing up' when there is brush bent forward under your tractor. The belly is exposed a bit, and even some wires and hoses to be considerate of while bush hogging.
But you can bush hog into areas of brush by backing into them with the mx6.
Break in shouldn't be anything special, other than the manual pointers. I wouldn't run full rpm (for the Mx6) until 10 hours or so. But I usually don't hog brush at full rpm anyway. Probably around half full. If I am cutting tall grass, then I crank it to the rec. PTO speed, as it does a better job of getting the grass cut. But lower rpm on brush seems to do sufficient, and I don't think has the potential to throw stubs around so much.
Setting the height of the mx6 may be the first challenge. Let it ride on the rear wheel with some slack to move up and down, independent of the dips and doodles the tractor does. Adjust the height of the front of the deck with the 3pt arms. I have my top link adjusted so at full height of the 3pt arms, the rear wheel is about 6" off the ground for 'travel' mode.
Lots of help here, so holler if needed. Also, a search of rotary cutters, bush hogs, etc. will give you several threads with good information and even good questions others have asked.
Alliance Flotation Tire (A50123)
Alliance Flotation...
PT 8' x 31' 6 Wheel Wagon (A50123)
PT 8' x 31' 6...
2019 Ford F-350 XL (A50123)
2019 Ford F-350 XL...
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2020 Ford F-250 Pickup Truck (A51692)
2020 Ford F-250...
