New 300 300X 300CX Loaders!
   / New 300 300X 300CX Loaders! #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
Three new loaders are now available for mid chassis. The cool one is the 300cx, which I will give a full blowout... For all this info, which is in the configurator at deere.com, I am not even beginning to figure out the compares to the 430, or competitors equipment...
300X Loader $3,159.00
For 4200-4400, 4210-4410, 870, 855 and 955 Tractors
Specifications Per ASAE 301.3
Measured @ Pivot Pin
Lift Capacity 1360 Lbs. (617 kg)
Lift Height 90 In. (2284 mm)
Boom Breakout 2855 Lbf. (12700 N)
Dump Angle - 43.3 Degrees
Rollback Angle - 25 Degrees
Quik-Tatch Loader
Quik-Tatch Carrier
Mounting Frame
Hood Guard
Bucket Level Indicator
61 In. (1550 mm) Materials Bucket
Buckets: 53", 61", 73", 61"HD
Pallet Forks 42", 48"
72 In. (1830 mm) Boom Mounted Front Blade
300CX Loader $3,699.00
For 4300-4400, 4310-4410, 970, 990 and 1070 Tractors
Measured @ Pivot Pin:
Lift Capacity 1598 Lbs. (725 kg)
Lift Height 102 In. (2593 mm)
Boom Breakout 3327 Lbf. (14800 N)
Dump Angle - 41.1 Degrees
Rollback Angle - 31 Degrees
Quick-Tatch Loader
Quick-Tatch Carrier
Mounting Frame
Hood Guard
Options:
<ul type="square">
[*]73 In. (1850mm) Materials Bucket $597.00
[*]61 In. (1550 mm) Heavy Duty Bucket with Holes for Cutting Edge 643.00
[*]73 In. (1850 mm) Heavy Duty Bucket with Holes For Cutting Edge $720.00
[*]73 In. (1850 mm) High Volume Bucket $865.00
[*]85 In. (2150 mm) High Volume Bucket $1,065.00
[*]Third Function Hydraulic Lines and Hoses $269.00
[*]Pallet Fork with 42 In. (1067 mm) Floating Tines $968.00
[*]Pallet Fork with 48 In. (1219 mm) Fixed Tines $849.00
[*]Bale Spear $490.00
[*]Tooth Bar for 61 In. (1550 mm) Bucket $289.00
[*]Tooth Bar for 73 In. (1850 mm) Bucket $337.00
[*]61 In. (1550 mm) Replaceable Bucket Cutting Edge with Hardware $97.00
[*]73 In. (1850 mm) Replaceable Bucket Cutting Edge with Hardware $118.00
[*]Skid Steer Carrier $380.00
[*]iMatch Quick Coupler Bushing Kit $31.00
[*]72 In. (1830 mm) Grapple Bucket $2,100.00
[*]60 In. (1524 mm) 4-IN-1 Bucket $1,265.00
[*]72 In. (1830 mm) 4-IN-1 Bucket $1,395.00
[*]72 In. (1830 mm) Boom Mounted Front Blade $1,220.00
[*]84 In. (2130 mm) Boom Mounted Front Blade $1,350.00
[*]Hydraulic Angling Kit for Front Blade $399.00
[/list]
What's with the iMatch Quick Coupler Bushing Kit listed for these loaders?!!
Finally there is the :
300 Loader $3,069.00
For 790, 770 Tractors
Lift Capacity 741 Lbs. (336 kg)
Lift Height 88.6 In. (2251 mm)
Boom Breakout 1729 Lbf. (7690 N)
Dump Angle - 40.5 Degrees
Rollback Angle - 24.3 Degrees
Quik-Tatch Loader
Quik-Tatch Carrier
Mounting Frame
Hood Guard
This is beginning to give me that TTT feeling...
   / New 300 300X 300CX Loaders! #2
I saw a new loader (not sure which one) on a 20 series CUT at our county fair this summer. I was pretty impressed that the uprights were cast. Mine are stamped and welded steel. These seemed to be very beefy parts. I don't know the 420/430 loaders that well but it appears there may be more to the new ones than just curved arms /forums/images/graemlins/smile.gif
   / New 300 300X 300CX Loaders! #3
I was at my dealer last week and they mentioned about a trip to Florida in a week or so for some new product releases. Wonder if that is when the new mid-chassis series will be announced.
Craig
   / New 300 300X 300CX Loaders! #4
any opinions on comparison to current (familiar) 420/430 FELs ??
my dealer priced me up a 4310 w/300x, when i was looking for the 430.
   / New 300 300X 300CX Loaders! #5
Man o Man, are you guys ever fast!!! I just found this site the other day while trying to find more info on the 300 series loaders. I'm a sales rep in Canada, and have decided this is my new favourite site!! You guys find the info faster than I can!
I'll be making the trip to Florida as well. John Deere should be releasing all the info on the 300 series loaders and new 3000 series tractors there!
Welcome aboard!!
We always like to hear from Dealership and Company folks!! Hope we can have fun!!
If you have any news, let us know! (we understand that you can't publish sensitive stuff...)
Hope you have a good trip way to Florida... When are the meetings?
430 Specs on 4300/4400
Front Tires 7.00-14 6PR R1
Rear Tires 11.2-24 4PR R1
Wheelbase (WB) 1726 mm (68 in.)
Material Bucket Width 1550 mm (61 in.)
Length (N) 618 mm (24.3 in.)
Mass 86 kg (189 lb)
Hydraulic System
Rated Flow 32.6 L/Min (8.6 gal/min)
Maximum Pressure 17.2 MPA (2494 psi)
Maximum Lift Height To Pivot Pin (A) 2575 mm (101.4 in.)
Clearance
Bucket Level (B) 2375 mm (93.5 in.)
Bucket Dumped (C) 1989 mm (78.3 in.)
Overall Length (WB+F) 3187 mm (125.5 in.)
Digging Depth (H) 155 mm (6 in.)
Reach
At Max Lift Height (D) 651 mm (25.6 in.)
Bucket on Ground (F) 1460 mm (57.5 in.)
Angles
Max Dump (E) 45°
Max Dump at Ground 130°
Max Rollback (G) 30°
Rollback at Full Height (SAE) 64°
Overall Height
In Carry Position (J) 1385 mm (54.5 in.)
Lift Capacity
To Max Height at Pivot Point (U) 572 kg (1258 lb)
To Max Height (V) 475 kg (1045 lb)
To 1.5 m (59 in.) at Pivot Point (W) 883 kg (1943 lb)
To 1.5 m (59 in.) (X) 765 kg (1687 lb)
With Forklift to Max Height (U) 345 kg (760 lb)
Breakout Force
At Pivot Point (Y) 14676 N (3299 lb force)
500 mm (19.7 in.) Forward of Pivot Point (Z) 10750 N (2417 lb force)
Bucket Rollback Force
At Max Height (VV) 9587 N (2155 lb force)
At 1.5 m (59 in.) Lift Height (XX) 14898 N (3349 lb force)
At Ground Level Line (ZZ) 13293 N (2988 lb force)
   / New 300 300X 300CX Loaders! #8
Excellent, an inside person from Canada! /forums/images/graemlins/wink.gif
I've always thought my 990 should have had a 460 loader instead of the 430, so this is a step in the right direction.
Now I need 2 things:
1. A Canadian price for the 300CX loader (or better yet an upgrade price difference for trading in a few months old 430 loader).
2. A picture of a 300CX on a 990. I'm assuming the 300CX has curved arms and I wouldn't want it to look too stupid on my "old fashioned" square nosed 990.
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / New 300 300X 300CX Loaders! #9
<font color="green"> PICTURES!!! We need pictures!!! </font>
   / New 300 300X 300CX Loaders! #10
Its your lucky day!!! I have pictures - BUT... I don't know how to post them /forums/images/graemlins/blush.gif
2025 CFG Industrial MX12RX (A50123)
2025 CFG...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
2011 WABASH 53x102 DRY VAN (A53426)
2011 WABASH 53x102...
7022 (A50322)
7022 (A50322)
2010 Toro ReelMaster Pull-Behind Hydraulic Reel Mower (A51691)
2010 Toro...
