New 3 pt hitch tree jaws puller.
   / New 3 pt hitch tree jaws puller. #1
vmj
Bardwell, KY
New Holland/TN75
1) ½ hydraulic hoses which have treaded ends without couplers.
Do I install the couplers with A) dry threads, B) threads with hydraulic oil on them, or C) something else (explain).
2) the new lines contains air. Will this be replaced by A) cycling the valve control lever (forward, neutral, backward) a few time, or B) something else (explain).
3) Tractor old female hydraulic coupler missing dustcap.
Was thinking about replacing or cleaning.
If cleaning, would use paper towels, q-tips, hydraulic oil, wd40, and compressed air. Was thinking it was okay as long as I did not depress the center valve.
   / New 3 pt hitch tree jaws puller. #2
   / New 3 pt hitch tree jaws puller. #3
1it realy depends on the type of fitting on the hose weather it is pipe thread or what they call ors ors is a strait thread like a bolt with an oring on it never use pipe dope on ors fittings
2yes the air will gradualy work its way out of the lines as you cycle the valve cycle it 5 to 10 times at low speed to get the air out otherwise you could have rapid movement of your cylinders due to compressed air in the lines
3 most female qd have an o ring inside them with a teflon backer a small amount of wd on a lint free rag wil clean and lube it nicely compressed air might blow the o ring out of the groove
UNUSED FUTURE BD43 HYD BACKHOE DIGGER ARM (A54757)
UNUSED FUTURE BD43...
STRICKLAND CASE 621D WHEEL LOADER FORKS (A52705)
STRICKLAND CASE...
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
2006 BOBCAT ZHS 435 FAST TRACK EXCAVATOR (A52705)
2006 BOBCAT ZHS...
2012 CATERPILLAR 316EL EXCAVATOR (A51406)
2012 CATERPILLAR...
2012 Ford Escape Limited SUV (A53424)
2012 Ford Escape...
