New 3 Point Tiller
/ New 3 Point Tiller #1
swatter
Bronze Member
Alabama
Kubota BX25D
Well I pulled the trigger and bought a new King Kutter II tiller. This 4 foot tiller is not the one made for a BX. I did a test run and the BX did not act like it was back there. I can't wait until this weekend to work it and see what it does. No more hand tilling the garden!
/ New 3 Point Tiller #2
You will like it.
I've had a King Kutter II tiller for years. Works great.
/ New 3 Point Tiller #3
It will serve you well. When I was in the market for a tiller I couldn't find anything around except the red 48" sub compact tiller with cat 0 pins. If I could have found one locally I would have bought the same one as you did. I finally ordered a Phoenix 48" from ETA and am very happy.
/ New 3 Point Tiller #4
Congratulations - it looks right at home on the back of your Kub.
You've probably done all this stuff, but just in case:
Remove the owner's manual from under the rear gate!
Check that you have gear oil in both gearboxes.
Grease the bearing zerks - PTO & main tiller rotor.
Slip the clutch.
Prepare for years of faithful service.
/ New 3 Point Tiller #5
Nice...try to post pics of a nicely tilled garden when you are done. I have been looking at this unit as well, but still using my walk-behind for now.
/ New 3 Point Tiller #6
Very nice , that's exactly what i would love to get also for my 2650, just wish they had more dealers closer to my area . As mentioned please let us know how things work out .
/ New 3 Point Tiller #7
I have a King Kutter Professional 48" tiller. I don't know what the difference is between the two.
Here is a picture I took that shows plowed ground and tilled ground and a video.
/ New 3 Point Tiller #8
DaveR - I think the Professional was quick hitch friendlier.
The sheet metal on the top is different, too - less open so as to shed water better and not collect stones, soil & leaves as easily.
/ New 3 Point Tiller #9
Thanks for sharing as your tiller and ground looks great. Tractor supply in my area sells county line products , Ive heard they are made by king cutter but not sure if that is true and if they are of the same quality as the equipment with the king cutter name on it . I noticed you have a county line mower . If you have any info on this it would be appreciated .
/ New 3 Point Tiller #10
Oh, man - this is getting me going. Thanks for posting.
The tax man got me this year, gotta eek out one more year of hand tilling.
HEC - the county line brand looks to be a cheaper mfg - it has a chain drive, where all the KK's at Fleet Farm store are gear drive.
/ New 3 Point Tiller #11
Same on I have on my BX. It's a beast. Don't forget front weight.
btw - Mine is TSC-CountyLine brand is exactly the same as the KK photo above except for the sticker. So maybe it depends where your TSC store is who sources the tillers.
/ New 3 Point Tiller #12
Thanks for the replies , I live in the Houlton Me. area so I will check tsc in Houlton . I have only checked the internet thus far , the internet implies the houlton tsc is out of stock now.
/ New 3 Point Tiller #13
Yup, another XX weeks and I can start tilling in Northern Virginia (snow still hasn't melted!!).
OP - baby that tiller, they are well worth it!
I couldn't afford a new one and couldn't find a good used one on CL so I bought a plow and was going to buy a harrow. Then a 5' KK tiller, lightly used, turned up on CL for $800, and was in my truck bed the next day. The plow will see limited use.
This is it after some fairly heavy use:
UNUSED KUBOTA RBUSH GUARD PARTS (A62130)
UNUSED KUBOTA...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
2020 DRAGON ESP...
Stainless Steel Commercial Prep Table (A60352)
Stainless Steel...
Bobcat S740 (A57148)
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
