NEW 22 HP ROBIN ENGINE
/ NEW 22 HP ROBIN ENGINE
Tomplum, thanks for the reply.
/ NEW 22 HP ROBIN ENGINE #22
You bet. Sounds like it will be purring along nicely soon.
/ NEW 22 HP ROBIN ENGINE #23
That's what i ended up doing. Bought a Kohler, but the shaft was larger than the Robins, then i found another Kohler, after i put mine in, that had same size diameter shaft as the Robins engine. I talked with Terry and he sold me a "kit" that i used some of the parts out of, to adapt the Kohler. Stepped me up a couple HP, and less noisy. Probably the best upgrade ive done to the 422.
Would you have the model # of the Kohler? I am in need of a new one to replace the eh65 22hp. How did the Kohler swap work out? Thanks
/ NEW 22 HP ROBIN ENGINE #24
Normally either will work as the engine should be secure to the chassis. What is important with a ground is that stays solid and is ideally located away from modules in case of voltage surges IE from jump starting as an example. You can always run a ground to both the chassis and engine.
I would connect it to the engine. Small amount of resistance counts when powering a starter motor. I am only an electrical engineer, but do have experience with starters.
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2013 JLG 8042 SKYTRAK (INOPERABLE) (A60736)
2013 JLG 8042...
John Deere S350 (A60462)
John Deere S350...
Toro z turn (A56859)
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2011 BIGHORN 5TH WHEEL RV TRAILER (A60736)
2011 BIGHORN 5TH...
