New 1025r optional LED Lights and brackets
   / New 1025r optional LED Lights and brackets #1
Jimh4662
In, MD
John Deer 1025r TLB
I ordered OPTIONAL John Deere LED lights on my new 1025r . Was wondering how to control the led separate from main switch. I understand the light switch lights up the whole lighting system. Maybe a separate ON/OFF toggle wired directly into the hot wire of the leds. Anyone with electrical knowledge that can advise. Thanks in advance.
   / New 1025r optional LED Lights and brackets #2
How did you end up liking the LED lights? I was thinking about adding this to a new tractor.
Yes, they are ok. They are brighter than expected. There isn't any specs on them but I estimate they are around 18 watt which seems pretty standard. They are factory OEM so wiring is a breeze. Plug and play. You'll need the brackets also.
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
2024 John Deere 872GP Articulated Motor Grader (A49461)
2024 John Deere...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2019 Ford F-450 4x4 Crew Cab Gooseneck Flatbed Truck (A49461)
2019 Ford F-450...
2019 VOLVO EC350 EXCAVATOR (A51242)
2019 VOLVO EC350...
2011 John Deere TX Gator 4x4 Utility Cart (A49461)
2011 John Deere TX...
