Neutral Safety switch
   / Neutral Safety switch #1
jstrainrn
Oroville
L48 Kubota
How does one bypass the neutral safety switch on the L48? My tractor is on site and can't get the tractor to start because the neutral safety is out of alignment.
   / Neutral Safety switch #2
The undersea PTO switch and the HST "neutral" switch interact. First, close the underseat PTO switch with a piece of velcro or a cable tie. This may resolve your problem.
Have you greased the Zerk on the HST pedal? Removed twigs and leaves from the transmission linkage?
When the Kubota dealer adjusts the HST neutral switch, you do not want them to adjust it too "fine". You want it closed over a fairly broad range from the central position. If Kubota service adjusts HST neutral switch too fine, the non-start condition will repeat over and over.
I did not adjust HST neutral switch myself, Kubota service did it for me.
This is from my personal experience. Use at your own risk.
Thanks ... Will see what we can do.
   / Neutral Safety switch #4
You don't Have to bypass anything...
Insure that tractor is in neutral (so it won't run over you).
Temporarily Jump from the large Positive battery cable on the starter solenoid to the small terminal on the starter solenoid... That will crank & start the engine.
   / Neutral Safety switch #5
My B21 forward/reverse safety switch give me intermittent problems too. Thanks to KennyV's post you can get it started. When you get the time for better fix I found this video on you tube. It is for a different model kubota but the concept is the same. I haven't done it yet but it is on my list. Spray lube on all the treddle linkages helped.
http://m.youtube.com/watch?v=xOSB4v4K1bk
   / Neutral Safety switch #6
WARNING SAFETY RANT
You have got to be joking! You are suggesting a very dangerous practise! I know you have said to put the tractor in to neutral first, but if anything can go wrong , it will. The only safe way to start the tractor is with the clutch depressed. This involves someone sitting on the seat.
Weedpharma
   / Neutral Safety switch #7
WARNING SAFETY RANT
Weedpharma
NO I was NOT joking...
He is wanting a way to start his machine so as to be able to Move it... NOT to do this as a routine method of starting.
Someone else setting there with the clutch in, will do NO more than One person paying attention. You may not be able to focus on a particular task long enough to prevent making a mistake, but I think the OP may do okay with a Minimal amount of caution... Without having to enlist another person to insure he not drive over himself...
   / Neutral Safety switch #8
The L48 is not a geared tractor so remote starting it will not cause it to move even if it is in gear. The HST pedal has to be moved forward or backwards to engage the HST.
A remote starter switch makes getting power to the starter solenoid. Those are made for the exact purpose the OP is looking for. Others have used such a switch for years. If its use killed people the nanny government would ban them for sure.
12 Volt Remote Starter Switch
   / Neutral Safety switch #9
It looks like I'm having the same problem described here with my L3200. With the key in the start position, slowly rocking the pedal intermittently gives me a rapid clicking/rattling noise. I want to bypass just the neutral safety to confirm or rule it out. Unlike the B serries, this switch has 4 wires. Can anyone tell me which pairs to jump and what each pair disables?
   / Neutral Safety switch #10
Thanks for this thread people. My B710 is sitting in the driveway after changing the trans/hydro fluid and filters now, it wont turn over. I'm just curious if I spilled some transmission oil on the switch. Can someone tell me where the evil thing is?
Thanks again, you've helped a lot on here.
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
MAHINDRA MAX 24 HST COMPACT UTILITY TRACTOR WITH LOADER (A52748)
MAHINDRA MAX 24...
2021 FORD TRANSIT 250 CARGO VAN (A52576)
2021 FORD TRANSIT...
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
VOLVO ECR88 EXCAVATOR (A52472)
VOLVO ECR88...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
