Neutral Safety Switch Issue?
   / Neutral Safety Switch Issue? #1
EddieM.
DR Brush Mower
My DR Brush Mower Neutral Safety Switch wire connection was knocked off. Mower wouldnt crank wouldnt do anything. I troubleshot the ignition etc. before realizing the problem simple fix right!! Reattached wire harness to safety switch, engine cranks but wont turn over!!
Like its not getting fuel! Starting fluid will turn it over and start for a second or so. My question is, Is this still a safety switch issue i.e. a bad switch or unrelated altogether? Thanks for any advice
   / Neutral Safety Switch Issue? #2
Wont turn over is wrong term, it usually equate to wont crank, wont spin up...... .... DO you mean wont start or run....
If it starts/runs on starting fluid I believe you have a fuel issue and not related to neutral safety switch....
checking wiring diagram would help to determine if tractor has electric fuel pump or shut off valve associated with safety switch circuit....
   / Neutral Safety Switch Issue? #3
It would seem more like the anti backfire solenoid below the carb had failed, or the fuel incombustible. The solenoid should have voltage and ground when cranking and in run position. Welcome.
Cummins Engine (A59230)
Cummins Engine...
2020 DRAGON ESP...
2013 Ford F-450 Dump Truck (A59230)
2013 Ford F-450...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
