Neighbors wild ride, backwards
   / Neighbors wild ride, backwards #1
MESSMAKER
Veteran Member
Bluegrass,KY
DK4710SE
My neighbor was unloading his new Holland 2600 from his trailer while it was backed down his driveway. He did not chock the wheels or support the rear of the trailer. When the tractor got about 1/2 way off, the front of the trailer raised the rear of the truck off from the ground. Down the driveway went truck,trailer,tractor and the neighbor. he managed to drive the rest of the way off the trailer before thing went really wrong. The whole trip lasted about 5 seconds and covered about 100'. He was lucky
   / Neighbors wild ride, backwards #2
Lucky is right. Guess he will be a little more careful in the future. Stuff happens so fast, good thing he was at home, not to far to go to change shorts. :laughing:
   / Neighbors wild ride, backwards #3
Known affectionately to some of us as "Trailer Surfing". BTDT, changed my drawers shortly after....;)
   / Neighbors wild ride, backwards #4
I saw something like that at a boat ramp once. As I recall it was a cabin cruiser behind a F250 coming out of the water. After clearing the water, the driver stopped on the ramp to check his rig. When he shut his door, the trailer popped off the ball hitch. The trailor toung flew up until the safety chains got tight. The high boat and the angle of the trailor lifted the rear of the truck until it began to slide towards the water. Then the trailer dropped down and the whole thing started over again. It didn't stop until the weight of the boat was supported by the water.
   / Neighbors wild ride, backwards #5
The term "All men are created equal" frequently comes into question on a typical boat ramp!
   / Neighbors wild ride, backwards #6
I like to think i am a pretty safety oriented guy but i would have never thought of that happening. I live in South Louisiana and we don't have any hills but we do have many boat launches, thanks for info I learned somthing today......
   / Neighbors wild ride, backwards #7
I think it would be substantially safer to drive the tractor back onto the trailor than continue backing off of a trailor + Truck rig that is backing up!
He is one VERY LUCKY sob.
   / Neighbors wild ride, backwards #8
This is why I place a block under the back of the trailer to take the weight of the tractor and prevent the truck from lifting in the air even on a level surface.
   / Neighbors wild ride, backwards #9
That might be easy and quick if you have HST, but 5 sec to shift and pop the clutch with out pulling a wheelie as you roll backwards downhill:confused2:
   / Neighbors wild ride, backwards #10
Clearly, we should be launching our boats with our tractors. :D
Vermeer SC802 (A50322)
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
2017 BAOLI KBG35 STRAIGHT MAST FORKLIFT (A51242)
2017 BAOLI KBG35...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
2018 Gatormade 20+5 Gooseneck Trailer (A52128)
2018 Gatormade...
(3) 14' X 14' ROLL UP DOORS, W/ MISC BRACKETS (A51244)
(3) 14' X 14' ROLL...
