Negotiate with JD x330...and engine upgrade worth it?
   / Negotiate with JD x330...and engine upgrade worth it? #1
me77
Whitesboro
craftsman
I'm looking to buy an x330 for $2950. I can upgrade to a Kawasaki engine for $3150. Should I do the upgrade? Also, can I negotiate price, or ask for freebies/add-ons?
...and would you recommend this tractor? why or why not?
   / Negotiate with JD x330...and engine upgrade worth it? #3
Much more important is to avoid the scrawny flimsy short lived K46 transmission . Which does the 330 have ? IIRC in the 2016 model year the x370 and up have a medium duty transaxle.
It has K46 hydrostatic integrated with transaxle... so I should avoid it?
   / Negotiate with JD x330...and engine upgrade worth it? #6
I think the engine upgrade is a good deal but also you need to get a more durable transaxle. I would spend the money to get a 3400 series or JD equivalent of that series by HydroGear which is what most mowers have in them. I don't know what JD uses but look at a better machine like the 5 series tractors by JD and you will have a longer lasting mower.
Look for a Kawasaki FS or FX grade engine to go with your 3400 or higher transaxle.
Okay, so the x330 is a no go. Unfortunately, it was above what I was hoping to pay, so I can't really go higher. Is there anything non-jd you guys would recommend?
   / Negotiate with JD x330...and engine upgrade worth it? #9
Check out the simplicity broadmoor line.
   / Negotiate with JD x330...and engine upgrade worth it? #10
X2
I had a early 2000's model and put 1500 or so hours on it. Probably the best cut of any mower I've ever used.
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
Unused 2025 CFG QK16R Mini Excavator (A50322)
Unused 2025 CFG...
2019 Kenworth T880 T/A Wet Kit Day Cab Truck Tractor (A50323)
2019 Kenworth T880...
2014 Chrysler Town and Country Van (A50324)
2014 Chrysler Town...
Dual/Moyno Pump System (A50121)
Dual/Moyno Pump...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
