needs help with a cav injector pump on a ford 3000
   / needs help with a cav injector pump on a ford 3000 #1
allycat
any help would be good
I just finished a rebuild on my ford 3000
all is back together and cant get the CAV injector pump to work
did the sprocket and pump timming as manual says
Allso have bleed the pump and fuel filters as manual says too
after letting the injector lines off at the injector end get nothing
no fuel at all
in the past when bleeding the fuel system it bleed pritty quickly
I have been though manual and everthing looks to be as it should be
I am at a loss what to do next any help or ideas would be good
thanks gav
   / needs help with a cav injector pump on a ford 3000 #2
Hi! First You must to have a lot of fuel at the pump input. If you have. Bleed the body injection pump start about 30 sec for remove air in the injection pump. After bleed at injector (start for bleed). If solenoid stop look for the connection. I think you have a lot of air in your system. Good luck! Oldmech
hi
What do you mean about If solenoid stop look for the connection
I dont get what you mean
it has lots of fuel out of the fuel tank
have got all the air out of the fuel filter and pritty certain all the air is out of the pump
but I will give it another try today
thanks for the help
gav
   / needs help with a cav injector pump on a ford 3000 #4
Hi! Only some new injection have solenoid cut-off. Important For start and bleed Put throttle at full speed. Good luck! Oldmech
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A49346)
Unused 2025 40ft...
2015 Chevrolet Silverado (A50323)
2015 Chevrolet...
Tree Boom (A50322)
Tree Boom (A50322)
1272 (A50490)
1272 (A50490)
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
1975 Dodge 600 Grain Truck (A50514)
1975 Dodge 600...
