needing this info please
   / needing this info please #1
jessicaray
cullmam al.
john deere 2010 301r 33hp
I have a john Deere 1020 301r maybe 70 something. Model and I need to know how the timing gear marks go there are horizontal lines with some number on each side of the lines ive looked every to find this
   / needing this info please #2
My 1020 manual shows the timing marks are aligned with a special tool, essentially a straight edge. With the straight edge aligned between the centerlines of the crank and camshaft gear, the mark on the cam gear should fall right underneath the straight edge. Same with the injector pump gear if you have a diesel. Presumably this is done with the crank on top dead center for #1 cylinder.
If this is not clear, ask your question in the John Deere Ag tractor subforum. Any you might put 1020 in the subject line - you'll likely get plenty of responses.
Jim
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51691)
2015 Ford F-550...
1969 Ford Continental Coupe (A51694)
1969 Ford...
AGT Mini Excavator Attachment Set (A50123)
AGT Mini Excavator...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
2013 PETERBILT 367 HOT OIL UNIT (A53843)
2013 PETERBILT 367...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
