Needing a new Utility+ Tractor - Looking for advice
   / Needing a new Utility+ Tractor - Looking for advice #1
tarkio
Montana
JD 2940
I have a JD 2940 that I use primarily as a loader tractor for feeding in the winter.
I have used this tractor the past couple years to run a small square baler and to stack hay as well.
I am looking for a new-to-me tractor that is physically smaller that will work better with a small square baler and be a little handier to do utility-type tractor work (post holes, harrowing pastures, etc). With that said, I wouldn't mind finding a tractor is around 60-65 hp, or more, so that I could also use it to run a round baler. I am on flat level ground so I may be able to get away with a lower powered tractor to run something like a JD 535. What is you opinion on that as well?
I have been lurking here gleaning information off and on for years and finally decided that I need to get more active here to learn more.
Thanks in advance.
For example, I am considering a JD 2440, maybe a 3020 or a 2355. I recently saw a 2755 that looked like it would work, size-wise.
   / Needing a new Utility+ Tractor - Looking for advice #3
Welcome to the forum tarkio,
Might wan't to look at the 5075M or 5085M that should put you in the 60-75 ptohp range.
   / Needing a new Utility+ Tractor - Looking for advice #4
The 3020 and 2355 are both good tractors imo. I used to have a 3020 and 4020 at the same time and while they were great tractors the newer 2355 with mfwd would be a better option to me.
I probably should have mentioned that I can't, or more appropriately, won't tie that much money up in a utility tractor.
I am hoping to, at best, stay in the low-teens for price.
Now, I may consider spending high-teens to ~$20k, if I can get a tractor that does what I described above and SAFELY handle large round bales. I could then sell my 2940 to help fund the "new" tractor.
   / Needing a new Utility+ Tractor - Looking for advice #6
I wouldn't hesitate getting a 2440. I've had a 2240 for 12 yrs and its done well for me. I'd consider another one if I was trying to save a little money and it was big enough for what I wanted to do. I bet any of the 55 series would be good too. If you wanted a newer rig, and if you don't mind an orange tractor, you should be able to find a fairly low houred M6800 Kubota with MFWD and FEL for under 20K. They are 62 pto hp.
   / Needing a new Utility+ Tractor - Looking for advice #7
Look for a 2350/2550 or 2355/2555 in the utility configuration (not row crop). It will be lower to the ground, have the clam shell rear fenders and overall just feel like a slightly smaller tractor despite having all the power and weight to handle round bales and baler.
Would a gas 2020 work to run a round baler on flat ground?
There is a local John Deere 2020 for sale that has a gas engine. That would simplify the purchasing and hauling the tractor by a long shot.
So, would a 2020 work to run a round baler on flat ground?
What about a Ford 3930? I know nothing of the Fords. Ran some as a kid farming for other people but I have never used one as a utility-type tractor.
UNUSED RAYSKY RM87-96 MOBILE TOILET (A54757)
UNUSED RAYSKY...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2019 INTERNATIONAL...
2023 BOBCAT E35 R2 SERIES EXCAVATOR (A52705)
2023 BOBCAT E35 R2...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
16FT Flatbed Truck Body (A52377)
16FT Flatbed Truck...
1998 12ft T/A Park Dump Trailer (A52377)
1998 12ft T/A Park...
