Needing a Disc Gang Axle...
   / Needing a Disc Gang Axle... #1
Travis_R
Veteran Member
Livingston Parish, LA
Yanmar YM2500
Does anybody here know where i can get a 1" x 22 3/4" square disc axle for a disc gang? This seems to be an uncommon length. Any good place online that custom makes disc axles?
Thanks,
Travis
   / Needing a Disc Gang Axle... #2
Check axle diameter again.
I looked through square Disc Axles at Agri-Supply. The shorter ones are 7/8", not 1".
Here is one 7/8" X 22-1/2", the extra 1/4" on your axle may be stretch. Or you may be able to compensate with thinner spacers or thinner pans.
LINK TO AGRI-SUPPLY:
7/8 X 22-1/2 Square Disc Axle
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52128)
Kubota SVL65-2...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2016 Ford Explorer...
New Idea Manure Spreader (A50515)
New Idea Manure...
1275 (A50490)
1275 (A50490)
